Magnetic field strength of a stack of magnets
7 replies · 5K views
xzy922104
I know that for a single cylindrical neodymium magnet, the formula
$$ \displaystyle{\displaylines{B(z)=\frac{μ_0M}{2}(\frac{z}{\sqrt{z^{2}+R^{2}}}-\frac{z-L}{\sqrt{(z-L)^{2}-R^{2}}})}} $$ shows the relationship between the magnetic field strength and the distance between the magnet. I was wondering if this formula still applies when several cylindrical magnets are stacked together, north pole to south pole? If it does not, is there any way that I could adjust it for situations involving stacked magnets? Thanks.
You assume that L in the formula of B(z) be replaced with nL where n is number of magnets stacked downward. It seems reasonable to me.
[EDIT]upward, not downward
That formula looks incorrect to me. In particular the minus signs (except between the two terms.Maybe $$ \displaystyle{\displaylines{B(z)=\frac{μ_0M}{2}(\frac{z}{\sqrt{z^{2}+R^{2}}}-\frac{z+L}{\sqrt{(z+L)^{2}+R^{2}}})}} $$
Please reference your formula.
I found the formula in this paper, under the section titled "Cylinder".
Oh I see his origin is translated by L relative to what I was considering. They are the same then. .Good
Would stacking the magnets affect the overall magnetic field in some way? Would this magnetic field be different from viewing the stack as a single, longer magnet?
As for the field on z axis , that you refer the formula, it is same as that of a single longer magnet.
Thank you all for your help!
