What causes magnetic fields in electric dipoles and moving electrons?
In summary, the conversation discusses the relationship between electric dipoles and moving electrons as sources of magnetic fields. It is established that both are caused by moving charges, but the specifics of how they contribute to the overall magnetic field are debated. The fundamental physics of Maxwell's equations is mentioned as a means to understand electromagnetism. It is also noted that the self-magnetism of an electron is a second-order effect and not a significant factor in major electromagnetic effects. Finally, a visual analogy is presented to explain the connection between the electric and magnetic fields.
JAL
[SOLVED] Magnetic fields qustions
I don't understand the correlation between the two following source of magnetic fields:
1- Electric Dipole
2- Moving Electron
I can't build a concept that allows me to explain them both! Are they both caused by moving electrons? #2 is by definitions but #1? In a permanent magnet, is it the motion of electrons of many aligned dipoles (like a selenoid) that cause the magnetic field?
I may be wrong, but i think its not so much the alignment of electrons but the spin. :shrug:
on the source of magnetic fields
I am under the impression that all magnetic fields are made by moving charges. Electrons orbiting in atoms make magnetic fields parallel to the axis of the orbit in addition to the field created by their spin. I'm not sure though how these combine to create or not the field of an atom. I guess a dipole would have a field too, but it depends on the releative angles of the axis' of the particles' spin.
An electric dipole consists of oppositely charged electric particles separated by a distance. There is no magnetic field associated with a dipole until it moves.
An electron being a single negative charge is surrounded by an electric, like the dipole there is no magnetic field until something moves with respect to (wrt) the electron.
A electric field changing wrt time(ie moving)generates a magnetic field, likewise a changing magnetic field generates an electric field.
So to directly answer your question, a neither a dipole nor a electorn automatically generates a magnetic field, The magnetic field is generated by motion of a electric field.
What?!
Now I'm no expert, but I'm pretty sure that electrons have a magnetic field as a result of their charge and spin. I thought that's what spintronics is all about, the manipulation of the direction of a electron's spin by using magnets to flip it one way or another.
Notwithstanding Jonathan's comment on spin, the electron is in constant orbital movement so it always moves so always generate a magnetic field. How else would you explain the magentic attraction between stationary atoms?
What does "changing with respect to time" really means. Does it mean move or accelerate or change direction or intensity or rotate?
I think he means in magnitude and/or direction, since those are the only ways for it to change.
A solitary electron is a single negitive charge, all spin effects are very small and negligable as far as a magnetic contribution.
An atom is an intirely different topic of discussion. Once again, while each "orbiting" electron generates a magnetic field the sum of all contributions (ie electrons) is essentially zero except for a few special cases (iron can hold a premenate magnetic field). Atoms can be diamagnetic, paramagnetic or feromagnetic, this is according to how they react to an applied magnetic field.
What I said in my original post is the fundamental physics you want to think about. This is the physics of Maxwell's equations which model the basic interaction of charges and electro magnetic fields.
Coulomb's law says that a region containing an electric charge is the source of an electric field.
Gauss's Law states that no region contains the END of a magnetic field line.
Faradays law relates a space changing Electic field and a moving charge to a time chaning magnetic field.
Orested law relates a space changing Magnetic field to a time changing Electic field.
Together these four equations (which I discibed but did not state) constitue the four Maxwell equations. Do some research on them if you wish to understand electro magnetism.
Edit: I had a major Typo in the last description. It now reads correctly!
Allright I get. Thx guys
Integral is correct. An electron
at rest is not generating a mag-
netic field. However it is gen-
erating an electric field which
radiates out in all directions.
Physically moving the electron,
whether it be by pushing it
through a conductor, or literally
shifting the position of a charged
piece of plexiglass causes a
kink in that electric field be-
cause the center of radiation of
that field is now in a different
position. It is these very kinks
in the electric field that are
the electromagnetic field.It's
that simple.
-Zoob
I disagree. An electron has spin and charge and so it has an unchangable and ever existent magnetic field!
You are quibbling over a 2nd order effect. Once again the self magnetism of an electron is very small, it is the source of the Zeeman effect this is observed as spectral line splitting in an applied magnetic field.
It is not a significant factor in major electro magnetic effects.
that simple.
-Zoob
That's a very good visual Zoob. Could I rephrase this by saying that the magentic field is effectively a result of a spatial imbalance in the electric field (ie. moving the charge in one direction has the effect of "superimposing" the electric field in the direction of the movement)?
JAL,
I'm glad it conjured up an image
for you.
I don't feel qualified to give the
O.K. to your proposed paraphrase
because I'm not sure that what
is happening falls into the cat-
agory of a superimposition. It
may, in fact, be more to the
point to visualize it as a com-
pression of the lines of force
of the electric field.
It was the discovery of this "kink
in the electric field" in an
encyclopedia, that finally allowed
me to pull everything in the EM
spectrum together in my mind.
Before this I didn't have a clue
how artificially produced radio
frequencies belonged together
with visible light, for example.
Is "spatial imbalance" a better
term than "kink"? I wish I knew
enough to say yes or no.
-zoob
A changing electric field (as might be created by wiggling a charge) creates a changing magnetic field. Similarly, a changing magnetic field creates a changing electric field.
- Warren
Warren,
Question on that phenomenon:
Where do I look for the wiggling
magnetic field in a stationary
charged object? Do the charges
"seethe" around, in and on it?
Or?
Zooby
Or?
The wiggling magnetic field around a stationary charge? What the hell are you talking about?
- Warren
Thank you, Warren.
1. What is an electric dipole?
An electric dipole is a pair of equal and opposite charges that are separated by a small distance. This results in a dipole moment, which is a measure of the strength and direction of the dipole. Examples of electric dipoles include water molecules and atoms.
2. How do electric dipoles create magnetic fields?
Electric dipoles create magnetic fields due to the movement of their charges. When the charges in an electric dipole move, they create a circulating current that generates a magnetic field around the dipole. This magnetic field is perpendicular to the direction of the current and is strongest at the poles of the dipole.
3. What role do moving electrons play in creating magnetic fields?
Moving electrons are the main source of magnetic fields. When an electric current flows through a wire, the moving electrons create a magnetic field around the wire. This is known as the right-hand rule, where the direction of the magnetic field can be determined by the direction of the current flow.
4. How are electric dipoles and moving electrons related in creating magnetic fields?
Electric dipoles and moving electrons are both sources of magnetic fields. In electric dipoles, the movement of the charges creates a magnetic field, while in moving electrons, the movement of the electrons themselves generates a magnetic field. Both contribute to the overall magnetic field in their respective systems.
5. Can magnetic fields be created without the presence of electric dipoles or moving electrons?
No, magnetic fields cannot be created without the presence of electric dipoles or moving electrons. In order for a magnetic field to exist, there must be a source of moving charges. This can be in the form of electric dipoles or individual electrons. Therefore, without the presence of these sources, magnetic fields would not exist.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
