Magnetic force b/w wires of unequal length
The discussion focuses on calculating the magnetic force between two parallel wires of unequal length. It suggests using the length of the shorter wire for calculations, but notes this is only accurate if the longer wire is significantly longer. The Biot-Savart law can be applied to determine the magnetic field of the longer wire, integrating it over the shorter wire. This method is emphasized as a valid approach for finite wire lengths. Overall, the conversation highlights the complexities involved in such calculations.
diagopod
Is there a formula for the force between two parallel wires of non-equal length? Would one just use the length of the shorter of the two wires?
That would only work if the longer wire were very much longer.
You can get the field of the longer, but finite, wire by the usual Biot-Savart integral with finite limits. Then integrate this field over the shorter wire.
Thanks, that does makes sense.
