Guineafowl
- 910
- 418
- TL;DR
- How would you characterise the energy transfer when changing the reluctance between two opposing magnets?
Someone on a machining forum is proposing a curiosity machine.
Imagine two magnets, constrained to move along one axis, set N to N. They will move apart. If you insert a piece of steel in the gap, the magnets will move towards it.
The input of the machine will be a rotating toothed disc/rotor, which will alternately present a gap, then a steel tooth, between the magnets, so causing them to reciprocate, and this motion will drive the output.
The load on the output and friction of the mechanism will, of course, be felt in the ‘cogging’ of the input rotor, but he’s asking for a more in-depth, mathematical explanation of the power transfer as the flux is switched.
If the toothed rotor were simply turning between fixed opposed magnets, I could explain the build-up of magnetic potential energy as one tooth is spun out of the field, which is then returned as the next one is attracted in. But this machine is doing work on the magnets. How would that work be calculated?
