Magnetic Susceptibility experiment using Faraday method
The discussion revolves around an experiment to calculate the magnetic susceptibility of inorganic compounds, specifically using the Faraday method. The original poster presents data collected from the experiment, including mass changes and magnetic field gradients, while expressing difficulty in converting results to cgs units.
  • Participants explore the conversion of magnetic susceptibility values from SI to cgs units, questioning the necessity and methodology of the conversion. There is also discussion regarding the validity of the equation used for calculating susceptibility and its dimensional consistency.
Some participants have provided guidance on unit conversion and raised questions about the original equation's derivation and correctness. The conversation includes attempts to clarify the relationship between different magnetic field types and their respective units, indicating a productive exploration of the topic.
There is mention of a lab manual providing the equation used, as well as references to published papers that support its use. Participants express uncertainty about the equation's components and their implications for the experiment's results.
maqdah
1. Good day,
Using 4-inch pole caps and a Mettler M5 balance, I got all the values required in order to calculate the magnetic susceptibility of several inorganic compounds such as Manganese (IV) oxide (MnO2). I have the change in mass of the tube with the sample of the compound when the magnetic field is on and when it is off. I got the mass of the sample as well as the region where the gradient of the magnetic field (dH^2/dx) (x being the vertical direction) is constant.
I know my values to be right but I am having a lot of trouble converting to cgs units.
2. Fx= m/2 * μ0 * χm * dH^2/dx
where χm is the mass susceptibility of the sample. 3. Let's take MnO2 as an example,
Fx = Δm*g = 0.0517 grams * 9.81
dH^2/dx = 6.29169 (This is the value of the slope of B^2 in Tesla squared and x in meteres
m= 1.1765 grams
This gives mass/specific susceptibility which is incredibly larger than the literature value (on the order of 10^6)
The literature value of the MOLAR susceptibility is 2280x 10^-6 in cgs units
hi maqdah! welcome to pf! :smile:
(try using the X2 and X2 buttons just above the Reply box :wink:)
m= 1.1765 grams
i don't understand why you're converting to cgs, or how exactly you got there :confused:
if you must have a cgs answer, just find the magnetic susceptibility in SI, then divide by 4π, see the pf library :wink:
cgs (emu) values:
Some books which give values of susceptibility use cgs (emu) units for electromagnetism.
Although susceptibility has no units, there is still a dimensionless difference between cgs and SI values, a constant, [itex]4\pi[/itex]. To convert cgs values to SI, divide by [itex]4\pi[/itex] for electric susceptibility, and multiply by [itex]4\pi[/itex] for magnetic susceptibility.​
(try using the X2 and X2 buttons just above the Reply box :wink:)i don't understand why you're converting to cgs, or how exactly you got there :confused:
cgs (emu) values:
It is true that susceptibility has no units but the equation that I am using gives me the mass susceptibility, which has units of length3/mass. Does what you suggest change?
Also, even if you plug in the numbers, I get a value of magnitude of few 103 instead of something close to 10-6 which begs a question, is my equation even correct in the first place?
hi maqdah! :smile:
maqdah said:
… the equation that I am using gives me the mass susceptibility, which has units of length3/mass.
eugh! I've never heard of mass susceptibility :confused:
but to convert length3/mass from SI to cgs, you'd multiply by (m/cm)3/(kg/g), = 106/103 = 103
(i haven't followed your calculations, you seem to have mixed SI tesla with cgs grams :confused:)
mass susceptibility is just the volumetric susceptibility (the dimensionless quantity) divided by the density of the material. Molar susceptibility is the mass susceptibility multiplied by molar mass.
So now I understood how to convert to cgs units (thanks plenty for that), but I keep getting this feeling that the equation is wrong. Because if you do some dimensional analysis, it just doesn't add up.
maqdah said:
… I keep getting this feeling that the equation is wrong. Because if you do some dimensional analysis, it just doesn't add up.
yup, i didn't understand your equation …
… where does it come from? :confused:
The teacher gave it to me in the lab manual. I even found the same equation in other previous published papers that did the same experiment.
hmm …
well, i don't understand why it's H instead of B, i don't understand why H is squared, and i don't understand why there's no charge
can you scan or link to any of those papers? :smile:
The first two pictures are the derivation. The equation is in the last picture. Equation 10. χ1 is the susceptibility of the surrounding medium which is air and that can be taken as zero. So we are left with the equation that I wrote.
http://www.freeimagehosting.net/vbkkf
http://www.freeimagehosting.net/6k7ij
http://www.freeimagehosting.net/n6st8
ah!
i] there's no m in there
ii] you're confusing the two different types of magnetic field
H is in amp-turns per metre, not tesla …
if you're using tesla, you need B2o, not µoH2
that's a lot of zeros! :wink:
tiny-tim said:
ah!
Im not sure I understand. So the equation become Fx = v/(2u0) * χm* dH2/dx?
yes, but with B (in tesla) instead of H
so your original χm is multiplied by µ02 times 103/4π
= 4π 10-11 ~ 10-10 :wink:
and the 103/4π is to convert it to cgs units? If yes I understand everything now :)
Thank you so much for your help. I really appreciate it.
yes :smile:
