Magnetics of transformers and induction in metals
Current in the primary coil of a transformer induces a voltage in the secondary coil, even when a sheet of steel, like a pipe, is placed between them. The ability to induce voltage through the steel depends on several factors, including the geometry of the steel, the type of steel used, the geometries of the coils, and the frequency of the current. It is important to note that it is the changing magnetic field (B field) that induces the voltage, not the current itself. The discussion highlights the complexities involved in transformer design and the influence of materials on induction. Understanding these factors is crucial for optimizing transformer and motor performance.
Sam Yerardi
If you have the primary and secondary coils of a transformer next to each other, then current will induce a voltage in the secondary coil, creating current flow. This question applies to motors as well. If I place a sheet of steel between the two coils, will I still induce a voltage? For example, say I have a steel pipe and inside the pipe I place a secondary coil of wire. Outside the pipe I place a primary coil. Can I induce a voltage in the secondary coil through the steel pipe?
The answer is yes, with a lot of qualification. How much induced voltage you get will greatly depend on specific geometry of the steel, the type of steel, the coil geometries, frequency, etc.
And, it's the changing B field that induces the voltage in the secondary, not the current.
Thanks. I guess I worded the question incorrectly. I meant the current in the primary coil. Thanks again!
Do you have a specific problem in mind?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
