Magnetism's Effects on Watches: Explained
  • Thread starter Thread starter Rudra Roy
    Magnetism
Magnetism affects watches differently based on their type. Mechanical watches can have their ferrous parts magnetized, leading to performance issues, while quartz watches are generally resistant due to their lack of moving mechanical parts. The Earth's magnetic field does not significantly impact watches because the strength is much lower than that of a magnet used in testing. Mechanical watches often include magnetic shielding to protect against magnetic fields, but if they do become magnetized, a watchmaker can demagnetize them. Overall, while quartz watches are less affected, mechanical watches can experience significant timing inaccuracies when exposed to strong magnetic fields.
Rudra Roy
Can anyone explain to me why does a watch stop when it is brought near a magnet?I want to know how does the magnet affect the watch.
The answer is depends on what "type" of watch. Digital/no moving parts? Mechanical?
In a mechanical watch, you are influencing the interaction of the ferrous mechanical parts. Some could become magnetized, permenantly affecting the watch's performance.
I have tried out with three types of watches.One of them is the spring-run watch of the olden days.Another one is the modern wrist watch, run on battery.And the 3rd one is also a modern wrist watch working on battery but the hands of the watch and the dial are made of plastic(none is digital).The magnet has no effect on the spring-run watch but it strongly effects the other two watches.So, we can see that a magnetic field affects the 2nd and 3rd watches.We know that the Earth has a magnetic field..So my question is that why Earth's magnetic field does not affect the parts of the watches, when it can affect a magnetic needle(since the parts of a watch are very small, I have compared their strength with that of a needle)?
I would be highly suspicious of a quartz watch being affected by a magnet. They do not have any mechanical motion outside of any physical hands and such. The timing mechanism, the quartz crystal, is fairly resistant to magnetic fields from what I know. A mechanical watch is affected because as previously stated the magnetization of the parts will create additional forces on the gears and such which will result in inaccurate running. A watch has to be very very precise to keep decent precision throughout the day, some mechanical watches easily run at around 20,000 beats per hour. That's 480,000 beats a day. If the watch gains say 4 seconds a day, then that means that each beat is only off on something of the order of a millionth of a beat. So even small imbalances can add up over time.
However, fortunately, any decent mechanical watch will have magnetic shielding in the form of a thick iron plate that sits behind the watch mechanism (though this is not there for watches with skeleton backs so that you can observe the mechanism). This help keep the watch from being affected by a magnetic field. If a watch does become magnetized, I have heard that the affects are rather pronounced, something on the order of minutes for each hour. A watchmaker can demagnetize the watch and correct the problem.
U are saying that the quartz watch should not be affected by a magnet.But then how does the magnet affect the watch?I have tested it several times.U can also test it.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
