Magnetizing Current: Questions Answered
  • Thread starter Thread starter tonyjk
    Current
The discussion revolves around the behavior of magnetizing current in transformers, particularly in loaded versus unloaded conditions. Participants explore the implications of magnetizing inductance and its representation in equivalent circuit models, addressing both theoretical and practical aspects of transformer operation.
  • Some participants assert that magnetizing current is always present, even under load conditions, and is a fraction of the primary current during full load.
  • There is a question regarding why magnetizing current persists in loaded conditions, with some participants seeking clarification on the role of magnetizing inductance.
  • One participant proposes that the inductance of the primary coil is equivalent to magnetizing inductance and questions the reasoning behind its parallel representation in the equivalent circuit.
  • Another participant suggests that the counter EMF produced by the secondary coil affects the primary coil's current, leading to an increase in primary current when a load is applied.
  • Participants discuss the relationship between applied voltage, flux, and the resulting currents in both primary and secondary coils, emphasizing the need for phasor addition in understanding these interactions.
  • There is a clarification that placing magnetizing inductance in parallel allows for a constant magnetizing current, independent of load current, which is contested by some participants seeking further explanation.
Participants express differing views on the nature of magnetizing current under load conditions and the representation of magnetizing inductance in equivalent circuits. The discussion remains unresolved, with multiple competing perspectives presented.
Participants reference the need for phasor addition and the implications of inductance on current behavior, but the discussion does not resolve the underlying assumptions or definitions related to these concepts.
tonyjk
Hello.. I have a question : why when a transformer is loaded on the secondary, in the primary coil there's still the magnetizing current? I know that's the magnetizing current is the current for the no load condition and it's used to establish the flux in the soft iron. But when a load conditon applies there's a bigger current in the primary coil so why there's also a magnetizing current? Thanks
Magnetizing current is present all the time, at no-load or in full load. During No-load whole of the primary current is Magnetizing current but during full Load, magnetizing current is only a fraction of the primary current.
In terms of equation
I_primary = I_magnetizing (No-load)
I_primary = I_magnetizing + I_secondary*K (Full-Load) (K is turns ratio)
However, I_magnetizing and I_secondary will not be in phase and won't add algebraically (needs phasor addition)
Yeah i know this but why there will always be a magnetizing current in load condition? Plus i have another question: the magnetizing inductance is also the inductance of the primary coil no? So why we put it in parallel in the equivalent circuit? And if this inductance is high how come there's an increasing current on load condition? Thanks again
Can we say that the inductance of the primary coil is the magnetizing inductance and when there's a current in the secondary it produce a counter emf in the
Primary coil so that's why the current increase?
So we can say that the equivalence impedance view by the source is the magnetizing impedance and impedance due to the counter emf produced by the secondsry coil in the primary coil?
PS: SORRY IM TALKING TOO MUCH
For any coil, E = N*d(phi)/dt. Always.
If E is the applied voltage phi will be the flux produced.
If phi is the applied flux to the coil, E will be the emf produced.
Lets look at this step by step.
1. When there is no load on the secondary side (i.e. No load condition)
E is the emf applied to the primary coil, then the coil will produce phi flux in the core.
You can see that, if E is sinusoidal, phi will be cosinusoidal.
The coil will consume that much current as required to produce the phi flux.
since, phi = N*I / reluctance_of_core we can calculate what will be the current required to produce the flux phi.
This current is the magnetizing current.
But since there is cosinusoidal flux in the core, the same rule applies to the secondary coil and there will be Emf induced in the secondary coil given by
E2 = N2*d(phi)/dt.
2. When there is Load in Secondary.
When you connect load to the secondary, then there will be secondary current. The secondary current flowing in the secondary coil will produce flux phi2 which will be in opposition with the flux previously being produced by the primary coil (by virtue of the primary magnetizing current). So, in effect the net flux in the core will reduce to phi-phi2. But Since Emf E is still being applied to primary coil, it demands that the flux linkage of primary coil still be phi. So what happens is the current in primary coil increases so that it now produces the flux: phi + phi2 so that the net flux linkage of the coil (that is flux in the core) becomes: phi + phi2 - phi2 = phi again. The additional current required in primary coil to restore the flux will not be equal to the current in the secondary unless the no. of turns are same in both of the coil. Hence, the secondary current that flows when load is connected to the secondary coil will be reflected in the primary coil on top of the already present magnetizing current (not as a replacement for it).
I hope you can now see the inner workings and understand why the magnetizing current is always present. Too answer in short, the flux produced by the secondary and the flux produced by primary would exactly cancel each other but because there is additional magnetizing current in primary, there will still flux in the core (hence the electromagnetic coupling)
I hope that wasn't too messy. I wish I knew LaTex.
Thank you but can anyone please explain wjy we p
ut the magnetizing inductance in parallel?
Because that's the only way the equivalent circuit diagram would correctly represent the physical model.
If it is put in series then magnetizing current will vary according to load current.
Only by putting it in parallel, the magnetizing current will be constant regardless of the load current.
thank you but even the current due to load is moving through the primary coil that's why i asked the question and still i didnt understand why
  • · Replies 36 ·
13K
  • · Replies 26 ·
