Magnitude and direction of k vector
The discussion revolves around understanding the magnitude and direction of the wave vector, denoted as k, in a physics context. Participants are examining the calculations related to the magnitude expressed in radians per centimeter and the implications of angles in vector representation.
  • Participants are attempting to clarify the calculation of the magnitude of k and its representation in terms of angles. Questions arise regarding the interpretation of the angle and its impact on the direction of the vector. There is also discussion about the significance of the numerical value obtained for the magnitude.
There is an ongoing exploration of the relationship between the magnitude and direction of the vector k, with some participants providing insights into the angle's role. Guidance has been offered regarding the representation of the direction as a unit vector, although no consensus has been reached on the interpretation of the magnitude value.
Participants note potential confusion regarding the angle measurements and the relationship between different representations of the vector. There is mention of misreading angles and the significance of the calculated values, which may reflect specific requirements or expectations in the homework context.
jaus tail
A light wave of wavelength 800 nm is directed in the x-y plane at 45o. For this propagating wave, 1) what is the magnitude of the k-vector?_________rads/cm
2) what is the magnitude of the k-vector?_________rads/cm
magnitude = 2(pie)/(wavelength)
I didnt understand the question. The magnitude is 2(pie)/wavelength. I get 78500 rad/cm which is pretty wrong as guess. Where would angle come into picture?
Ref: https://www.millersville.edu/physics/experiments/062/index.php
Shouldn't direction be like i + j + k ?
So will it be like:
|k|cos30 i + |k| sin30 j + 0 k ?
And misread the 45 degrees ? And the fact that 1) and 2) are identical ?
Says who ? I get the same. Perhaps they want to see 78540 ?
Yes, but ##\pi/4## instead of 30.
Picture has ##\vec k## pointing in ##-{\pi\over 4}## direction.
To be honest this is all so maths. Thanks for this. What does 78540 signify. I mean so much radians / cm.
Shouldn't direction be unit vector like
The vector you mentioned divided by |k|?
I get ##2\pi/##(8*10-5 cm) = 78539.82 rad/cm
If you want. One can also say that is the unit vector in that direction.
Thanks for the guidance.
You are welcome.
10K
10K
11K
