Magnitude of changing magnetic field
The discussion centers on calculating the rate of change of a magnetic field through a square loop with a resistance of 4.00 Ω and an area of 600 cm². Using the formula ε = -NΔΦ/Δt, the correct calculation yields a rate of change of the magnetic field (ΔB/Δt) of 200 T/s when a 12-volt battery is connected. The initial misunderstanding involved confusing the total voltage with the induced electromotive force (emf) in the loop, which was clarified by recognizing that the problem specifically asked for the rate of change, not the magnitude of the change.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with the concepts of electromotive force (emf) and magnetic flux
  • Basic knowledge of circuit components, including resistance and voltage
  • Ability to manipulate equations involving magnetic fields and induced currents
  • Study the principles of Faraday's Law in greater detail
  • Learn about Lenz's Law and its implications on induced currents
  • Explore practical applications of electromagnetic induction in circuits
  • Investigate the relationship between magnetic field strength and induced emf in various configurations
Students studying electromagnetism, physics educators, and anyone interested in understanding the principles of electromagnetic induction and circuit behavior.
likthem
A square loop consists of a single turn with a resistance of 4.00 Ω. The loop has an area of 600 cm^2, and has a uniform magnetic field passing through it that is directed out of the page. The loop contains a 12-volt battery, connected as shown in the figure below.
At the instant shown in the figure, there is no net current in the loop. At what rate is the magnitude of the magnetic field changing?
Φ=BAcosθ
ε=-NΔΦ/Δt
ε=-NΔΦ/Δt
ε=-NΔBAcosθ/Δt, A is constant so
ε=-NAΔB/Δt
ΔB/Δt=ε/NA, negative sign is removed because only magnitude is asked for.
ΔB/Δt=12V/(1)(0.06m^2)=200T/s
I worked this out and it turned out to be wrong. I put in 12V as the emf as I thought that the total voltage should be the same as there is no net current in the loop, however that is the only part of the problem that I am uncertain about. The answer must be in T/s.
Thank you in advance for the help.
Never mind, I got it. It wasn't asking for what was the magnitude of the change in magnetic field but the rate of change. Since the induced current from the field will be opposite to the that of that in the loop, the answer should be negative. So I did it correctly, just misread what the problem was asking for.
Thank you!
16K
16K
10K
