How can I create my own video player using my Sony Ericsson cell phone?
  • Thread starter Thread starter jwxie
    Video
Creating a custom video player using a Sony Ericsson Walkman phone involves several components, including a screen, a processor, and software. A pre-built ARM board and a compatible video controller are recommended, along with installing Linux and open-source player software like mplayer. However, the project may exceed the budget of $30 and could be challenging for a beginner due to the technical complexities involved. Alternative suggestions include exploring simpler projects that could still showcase creativity for an admission application. Successfully completing this project could provide valuable skills for future engineering opportunities.
jwxie
I have an idea. I need some helps:
I have a sony ericsson cell phone (a Walkman series). What I want to do is to take out the screen (I don't know whether it is a LCD or just plain glassy screen, please correct me).
Basically I want to make my own little video media player. I just want to make a cheap one for fun - not for sales or anything. Simple one.
What exactly do I need to accomplish this?
[1] a screen
[2] a processor
[3] a program
Can you guys give me a deep help, in great detail what exactly I need??
I am a rookie, thanks for help.
That is a big project, especially for a rookie.
The way to go is probably to get a pre-built ARM board like this one
http://www.embeddedarm.com/products/board-detail.php?product=TS-7200
and a video controller like this one
http://www.embeddedarm.com/products/board-detail.php?product=TS-7KV
and hope that it's compatible with your LCD screen. Then you'd install Linux on the board, find open source player software such as mplayer, build it and upload onto the device. It won't be cheap and it won't be particularly easy. And the device won't be able to play anything beyond 320x240 resolution (if that), because the 200 MHz processor isn't powerful enough.
wooo thanks hamster..
$119 for that board...wooo
i was thinking about those $20 budget robotics project i did lmao
well here is the case.. i want to do this because i need it for my cornell admission application. i want to surprise them and let them see my creativity and uniqueness, so the cost cannot be high... i mean max is around $30 which seems impossible ATM, since media processor is not the same as those robotics processor range from $5 - 20, since the technology itself is different...
The screen is just the regular cellphone size, those 4cm x 3cm one...
i don't know... but you are giving me something valuable, thanks! and yes, i just want to do a simple one - play / stop by switching the system on and off - this is easy, just a little trick with the programming...
any suggestion that you think is helpful... any suggestion to make this possible, for now?
(i am a freshman engineer so i really don't have that deep experience in EE)
but greatly thankful for your reply!
TI makes some inexpensive video processors with MPEG/H.264 decoding support, such as TMS320DM355 ... but figuring out how to integrate one of those into a complete product will be difficult, to put it mildly. And you still need an ARM development board to put it into...
On the other hand, if you do figure out how to build one, that's probably a useful real-world skill that might help you get a job as an embedded engineer eventually.
Maybe someone else here can think of something that I overlooked.
If you don't want to go to such great lengths, surely you can think of something simpler to impress Cornell guys.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
