Make Hot Wire with 9V Battery: 200c/300c
  • Thread starter Thread starter yup790
    Hot Wire
To create a boiling tube that heats to 200°C using a 9V battery, a coil of wire is suggested, but a standard PP3 9V battery may not provide sufficient current, as it typically supplies only 300-400 mA for a short duration. A more effective option would be a 12V 7.2 AH Gel or sealed Lead-Acid battery, which can deliver the necessary current for longer periods. Achieving 200°C can be done with a thin wire that glows red at around 2A, while using a thinner wire could reach this temperature with just 200mA. Proper insulation of the system is crucial for maintaining the desired temperature. Overall, using the right wire material, such as tungsten, and ensuring adequate insulation are key factors in successfully heating the system.
yup790
I am planning in making a boiling tube that heats up to about 200c without a flame. I was thinking a coil of wire and a 9v battery (portable is always better). How would I make the wire hot - 200c/300c with only a 9v battery.
If you insulate your system well enough (that is not trivial), reaching that temperature is easy.
Controlling the temperature can be interesting.
Yup, but it isn't going to be done with one of those small PP3 9V batteries, they just don't have the umph,
they can only supply around 300-400 mA and for a relatively short time
You would need a battery that can supply significant current, say a 12V 7.2 AH Gel or sealed Lead-Acid
Dave
I don't know how large the volume we want to heat is.
You can make a thin wire visibly glow red with ~2A, using a thinner wire should easily give 200°C with 200mA.
9 V at 200 mA means 40 Ohm, so we can use a long thin wire (or probably a small resistor).
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
Hello! I would like to apply an electric field of 100 V/cm, along the z-axis (defined by an externally applied DC field), with a frequency of 100 MHz at the location of an atomic cloud (everything is inside ultra high vacuum). We can assume that the atoms are located in a volume with a diameter of 50 microns (e.g. in an optical dipole trap). However, I need to minimize any induced magnetic field along the z-axis at 100 MHz as much as possible (ideally at the nano Gauss level or below). Does...
