Can a Hybrid Lightning Jet Engine Outperform a Traditional Jet Engine?
The discussion centers on the feasibility of a hybrid lightning jet engine outperforming traditional jet engines, with claims that lightning can heat air significantly more than the sun. Participants explore the idea that a hybrid engine could utilize lightning to expand heated air, potentially improving fuel efficiency. However, the conversation reveals a misunderstanding of jet engine mechanics, with one user clarifying that the F-35's name does not imply it is powered by lightning. Ultimately, the thread concludes with a reminder of the basics of jet engine operation, leading to its closure. The discussion highlights misconceptions about jet propulsion technology.
obliqueweapons
Does lightning heat air 5 times more the the suns surface? If so can a hybrid lightning jet engine work, as lightning heats up air, more then fuel can?
Americas 5th gen jet fighter can travel 3* more then enemy jet's. That means it's a hybrid engine right?
Compressed air heated sees the air expand making it's speed pick up or fly faster, or fly longer as the engine turbines make electricity?
I take it the jet fuel also powers the electricity by using lightning, to heat the air expanding it also, saving fuel?
To save fuel the F-22 jet must use 50% less because the electric power turbines, are making the jet powered by lighting strikes, that expand the air making thrust at the same time, meaning less fuel as the blades turn, they make electricity?
Big lightning heats the air on Earth 5* hotter then the sun. This means any lighting can hit compressed air making it expand from heating it up with lightning right?
As you can see i am far from a scientist, or good at gramma...Sorry peoples.
The name of the F-35 is the "Lightning". That doesn't mean it's powered by lightning, any more than the F-18 hornet is powered by bees.
Likes berkeman, CWatters and Doc Al
I'm not sure if this was intended as a serious thread or not, but that OP is basically gibberish, bearing no resemblance to how a jet engine works. There is nothing special about the F-35's engine. Here's a place to start learning about how jet engines work:
https://en.wikipedia.org/wiki/Jet_engine
Thread locked.
Likes davenn
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 35 ·
