Troubleshooting Mandl & Shaw QFT: Deriving eqn (9.94) on pg 192 of 2nd edition
  • Thread starter Thread starter Vic Sandler
Vic Sandler
I tried to derive eqn (9.94) on page 192 of the second edition of Mandl and Shaw QFT and failed. Can someone help me see what I am doing wrong?
Ignoring factors that do not change from eqn (9.92) to eqn (9.94), noting that f(k) has been set to 1, and dropping terms linear in k and k squared as described in the text, I get:
\frac{\gamma^{\alpha}(\not{p'}+m)\gamma^{\mu}(\not{p}+m)\gamma_{\alpha}}{((p'-k)^2 - m^2)((p-k)^2 - m^2)}
= \gamma^{\mu}\frac{(-2p'p)}{(-2p'k)(-2pk)} + \frac{4m(p' + p)^{\mu}}{(-2p'k)(-2pk)} + \gamma^{\mu}\frac{(-2m^2)}{(-2p'k)(-2pk)}
The first term on the right hand side is the same as in the book, but divided by -2. Perhaps the other two terms combine in some way to fix it up, but I don't see it. I also don't see what terms are meant by the author when he says "the dots indicate terms which are finite in the limit \lambda \rightarrow 0" since none of the terms involve \lambda.
Let us see only the p/ . p'/ term.
γα/p'γμ/pγα=[-/p'γα+2p'αμα(-/p)+2pα),now /p and /p' operating on free particles states will give m which will cancel with the m already written in (/p+m) and (/p'+m) terms.You are left with
2p'αγμ2pα,so you will get 4 in the numerator not 2.
Likes 1 person
Thanks Andrien, that helps a lot. But it still leaves the middle term:
Do you have any ideas about it?
There are no such terms because as I have written earlier owing to -/p(-/p') acting on free particle spinor you get a factor of -m which will cancel with m in (/p -/k +m) and also dropping linear terms and quadratic terms in k,you are left only with the first term already written in the book.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
