Mass of field for small fluctuations
h0dgey84bc
Hi,
If I have a Lagrangian that looks like L=-\frac{1}{2} \partial^a{\phi}\partial_a{\phi}-\frac{1}{2} \mu \phi^2 -\frac{1}{24}\lambda \phi^4.
Where \lambda>0
Then how do I figure out the mass for small fluctuations about \phi=0 ?
I don't think I really understand what it means for some parameter to represent the mass. I mean without the phi^4 term, it would just lead to KG equation and obviously there \mu represents the mass when you find the dispersion relation.
Should I just therefore find the equations of motion, then plug in some superposition type solution to find out the dispersion relation, and thus find a term that I would normally call the mass in a relation of the form E^2=P^2+m^2? or is there something else to this?
I'm not really sure how to incorporate the phi=0 expansion into this, I was originally thinking just Taylor expand but then I would have expanded about \phi(0,\vec(0)), as oppose to the trivial \phi=0 solution.
Thanks for any help
I will only comment in the context of classical field theory, because I think it is not necessary to mention detailed aspects of QFT.
I think you already have the correct idea. The mass of the field is determined by its behaviour for small values of the field \phi. This means that you can simply neglect the quadric term.
If you want to actually do a Taylor expansion, you can construct the action integral and do a Taylor expansion with functional derivatives around \phi=0, but the end result will be the same.
Lots of more complicated answers can be given, involving quantization, representation theory of the Lorentz-group, mass renormalization with bare masses and dressed masses, singularities of propagators, and so on. But I believe what I mentioned above is a pretty reasonable definition in the context of classical field theory. If you are interested in more detailed aspects, consult Weinbergs first QFT book.
One thing to watch out for with this kind of approximation. After you have assumed that \phi is small, you have to make sure that the solutions in the approximative theory don't grow to become large... That would be inconsistent. But in this case, your approximation of small \phi leads to a linear equation of motion, so all is well!
Torquil
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
