Mass of object in Escape velocity
Escape velocity is primarily determined by the mass of the central body and the distance from its center, not the mass of the escaping object. The formula for escape velocity includes both the mass of the central body and the escaping body, but the latter's contribution is negligible for practical scenarios. For example, the mass of an object would need to be extraordinarily large, around 10^15 kg, to significantly affect the escape velocity from Earth. This is equivalent to the mass of about 100 mountains, making it impractical in real-world applications. Thus, the escape velocity remains effectively constant regardless of the mass of the escaping object.
asmalik12
Why doesn't the escape velocity depend upon the mass of body?
Why doesn't the height reached by a tossed ball depend on the mass of the ball? Same thing. (As is often the case when dealing with gravity, the mass drops out.)
It does. The correct equation is
v_e = \sqrt{\frac{2\,G(M+m)}r}
The capital M denotes the mass of the central body, the little m, the mass of the escaping body.
Now think about how big that little m needs to be to make any measurable difference in the velocity needed to escape Earth orbit. Escape velocity from LEO is about 11 km/s. Suppose we can measure velocity down to the micrometer/second range, or 10 significant digits. That corresponds to a mass of 1015 kg, or the mass of about 100 mountains.
We aren't going to launch a 100 mountain mass out of Earth orbit any time soon.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
