Masses on an inclined plane and their Lagrangian
The discussion centers on the dynamics of a wedge and a cube on an inclined plane, analyzed using Lagrangian mechanics. The Lagrangian for the system is given as \(\mathcal L=\frac{1}{2} M \dot{x}_1^2+\frac{1}{2}m(\dot{x}_1^2+\dot{x}_2^2-2 \dot{x}_1\dot{x}_2 \cos\theta)+(M+m)gx_1 \sin\theta\). The Euler-Lagrange equations derived from this Lagrangian reveal that the horizontal component of the momentum of the mass \(m\) is conserved, specifically expressed as \(\dot{x}_2 + \dot{x}_1\cos\theta\). The discussion also highlights a sign error in the kinetic energy term of the Lagrangian, which affects the conservation laws being analyzed.
  • Understanding of Lagrangian mechanics
  • Familiarity with Euler-Lagrange equations
  • Knowledge of inclined plane dynamics
  • Basic concepts of momentum conservation
  • Review Lagrangian mechanics and its applications in classical mechanics
  • Study the derivation and implications of Euler-Lagrange equations
  • Explore examples of inclined plane problems in physics
  • Investigate conservation laws in multi-body systems
Physics students, mechanical engineers, and anyone interested in advanced dynamics and Lagrangian mechanics.
ShayanJ
Insights Author
Consider the configuration below shown in the attached picture!
The wedge can slide on the inclined plane and the cube on the wedge.Their motion is described by x_1 and x_2 respectively. There is no friction and the inclined plane doesn't move.
Here's the Lagrangian of the system:
<br /> \mathcal L=\frac{1}{2} M \dot{x}_1^2+\frac{1}{2}m(\dot{x}_1^2+\dot{x}_2^2-2 \dot{x}_1\dot{x}_2 \cos\theta)+(M+m)gx_1 \sin\theta<br />
And the Euler-Lagrange equations are:
<br /> M\ddot{x}_1+m(\ddot{x}_1-\ddot{x}_2\cos\theta)=(M+m)g\sin\theta\\<br /> m(\dot{x}_2-\dot{x}_1\cos\theta)=const<br />
I want to know,what is the constant of motion appearing above?
One may expect it to be the component of total linear momentum parallel to the ground but it can't be that because it doesn't involve M.So what it is?
Thanks
Don't know the answer to your question but if there is no friction won't both masses accelerate together?
Of course the motion of M may cause m to move, whether there is friction or not.
It's the horizontal component of the momentum of the mass m (The top block), obviously...
No, the horizontal component of the momentum of the mass m is \dot{x}_2 + \dot{x}_1\cos\theta.
Anyway, still another question remains. So where is the horizontal component of the momentum of the wedge?That should remain constant too.
You must've made a sign mistake somewhere than because that's the one quntity that 's conserved in this problem
No because the normal force between the wedge and the fixed incline pushes the wedge sideways.
If there is no friction, the small block will have no horizontal motion. Unless it had some initial horizontal speed.
And are you sure you have that minus sign in the kinetic energy?
Yes, there is a sign mistake in your Lagrangian. the term with a cosine in it should be positive.
Not, obviously both speeds have a common positive direction which means they should be added to give the speed relative to the inclined plane.
The normal force is equal and opposite to (M+m)g\cos\theta, and so is canceled out.Otherwise there could be an acceleration normal to the inclined plane which causes the wedge to fly away!
The sign mistake is in the Lagrangian
You're getting confused. We're talking about horizontal components. (M+m)g\cos\theta isn't horizontal. Gravity has no horizontal component.
Why do you tend backward when the bus you're standing in accelerates forward?
Yeah, Looks like that should be positive.
But still the problem remains that where is the x component of the momentum of the wedge?
Or why isn't that conserved?
Yeah... I got that.
In fact we're confusing two different horizontals!
Gravity has no component parallel to the ground. But it has a component parallel to the inclined plane. When you talk about the normal force from the inclined plane to the wedge, the weight of the wedge does make a contribution.
I already answered that question. You may not have believed my answer but it is in fact correct.
You need to hone your intuition a bit more.
Shyan said:
Yeah... I got that.
When I say horizontal I usually mean the actual horizontal.
If you mean this:
I already answered that too. If it wasn't canceled, it would give the wedge an acceleration normal to the inclined plane! It is canceled by the component of the weight of the wedge normal to the inclined plane.
Shyan said:
If you mean this:
That's ridiculous now. We're talking about the HORIZONTAL component of the normal which cannot be canceled by gravity. You're stuck thinking about perpendicular and parallel components to the incline. I'm talking about HORIZONTAL component.
Another way to look at it is that the normal is canceled by one component of gravity, but the other component of gravity accelerates the wedge down the ramp and that acceleration has a horizontal component. Either way there is a horizontal acceleration.
Ohh...dammit...yeah...sorry. This was a problem with the word. It was like my mind wasn't interpreting the word horizontal correctly. That's a problem when you're not a native speaker. Sorry.You're right.
For the horizontal direction, the small block moves (accelerates) in respect to the wedge but not in respect to the ground or the inclined plane.
Yeah,That's the thing one of the equations is telling us. Its horizontal component of momentum is conserved. I was talking about motion w.r.t. the wedge.
  • · Replies 21 ·
  • · Replies 76 ·
