Material balance with a reaction (chemical engineering)
5 replies · 7K views · last reply
MickeyBlue
Felder & Rousseau 4.73 (p. 184)
A mixture of propane and butane is burned with pure oxygen. The combustion products contain 47.4 mole % H2O. After all of the water is removed from the products, the residual gas contains 69.4 mole% CO2 and the balance is O2. What is the mole percent of propane in the fuel?
1. Let propane = P
2. Choose 100 mol of the reactant fuel as a basis
[/B]
Set up 2 balanced equations: 1. C3H8 + 5O2 -> 4H2O + 3CO2
2. C4H8 + 13/2O2 -> 5H2O + 4CO2
I assumed a 100% conversion of the reactant gases. I know O2 is in excess. I drew up a reactant table in terms of mol and set Propane in = P and Butane in= 100-P. I then tried to calculate P by setting the mols of water out divided by the total mols out equal to 0.474.
Hello @MickeyBlue! Welcome to Physics Forums! :smile:
:welcome:
1. Let propane = P
[/B]
So far so good, with one exception:
You wrote that the butane was [itex]\mathrm{C_4 H_8}[/itex], but I think you meant [itex]\mathrm{C_4 H_{10}}[/itex]. Your equations were balanced correctly though, so I assume that was just a minor mistake typing things into the computer.
As a hint for moving forward, don't forget to include the leftover [itex]\mathrm{O_2}[/itex] in your product. Similar to what you did with [itex]P[/itex], make up a variable name to indicate the amount of [itex]\mathrm{O_2}[/itex] in there. I used the variable [itex]x[/itex], but you can use whatever you want.
So your formula, as you have already stated it, should be of this form:
[tex]\frac {\mathrm{moles \ of \ H_2O}}{(\mathrm{moles \ of \ H_2O}) + (\mathrm{moles \ of \ CO_2}) + (\mathrm{moles \ of \ O_2})} = 0.474[/tex]
After that, take out the [itex]\mathrm{H_2O}[/itex] and do something quite similar except with [itex]\mathrm{CO_2}[/itex] in the numerator (and the ratio value being different).
If you do things right, you'll have two equations and two unknowns ([itex]P[/itex] and [itex]x[/itex]). :wink: That's enough to solve for [itex]P[/itex].
Chestermiller said:
So, what's the problem?
My final answer for propane was well above 100 and I couldn't understand why.
Show your work, and perhaps we may be able to point you in the right direction.
Oh! Thank you, I see where I went wrong now. Because of how I added mols of O2 consumed I took it as the amount in excess instead. You're right; this should be enough to get P.
