Math behind rockwell hardness measurement
The discussion focuses on calculating the force of a pin impacting solid metal using the Rockwell hardness measurement method. The user has detailed knowledge of the indenter shape, indentation depth, and mechanical properties of the metal, including modulus, yield, and ultimate strength. The Rockwell method involves applying two forces, F0 and a significantly larger load, to determine hardness based on indentation depth. The conversation also references the importance of selecting the correct indenter type, specifically mentioning the 1/16 inch sphere and its associated Rockwell notations (HRB, HRC).
  • Understanding of Rockwell hardness testing methodology
  • Familiarity with mechanical properties of materials, including modulus, yield strength, and ultimate strength
  • Knowledge of ultrasonic wave guide mechanics
  • Ability to interpret Rockwell hardness tables and notations
  • Research the Rockwell hardness testing standards and procedures
  • Study the mechanics of ultrasonic wave guides and their applications in material testing
  • Explore the relationship between indentation depth and hardness values in various materials
  • Examine different types of indenters and their specific applications in Rockwell hardness testing
Materials scientists, mechanical engineers, and quality control professionals involved in hardness testing and material characterization will benefit from this discussion.
metjim
I need to calculate the force of a pin impacting a solid metal. I know the shape of the indenter, the precise shape and depth of the indentation and the mechanical properties of the solid metal including modulus, yield and ultimate strength. The pin is being driven by ultrasonic wave guide so it is not simply a gravity problem.
In my mind this is the basic equation that Rockwell Hardness uses with the exception that they know the force and indenter shape and measure the depth of indentation to calculate hardness.
Does anyone know how to solve this?
Thanks
If you are referring to the standard Rockwell method then there are two forces that are applied, the first F0 is applied first then another load, significantly larger than the first, is applied.
Considering your case you could sort out the list of indenters and their respective Rockwell notation (HRB,HRC..etc) and then look at the force value. Now I have a Rockwell table at hand over here but it is in my national language and from what I can see unless you're indenter is a 1/16 inch sphere, you're safe. Since there's pretty much about five different options with a 1/16 inch sphere.
9K
  • · Replies 24 ·
  • · Replies 24 ·
10K
  • · Replies 31 ·
  • · Replies 27 ·
10K
