Challenge Math Challenge - August 2019
fresh_42
Staff Emeritus
Homework Helper
Insights Author
2024 Award
Questions
1.
(solved by @Pi-is-3 )The maximum value of ##f## with ##f(x) = x^a e^{2a - x}## is minimal for which values of positive numbers ##a## ?
2. (solved by @KnotTheorist ) Find the equation of a curve such that ##y''## is always ##2## and the slope of the tangent line is ##10## at the point ##(2,6)##.
3. (solved by @nuuskur ) Let ##F_q## be the finite field with ##q## elements and ##n \geq 1## with ##(n,q)=1##. What is the smallest field extension of ##F_q## containing an ##n##-th root of unity?
4. (solved by @nuuskur ) Show that there is no infinite countable ##\sigma##-algebra.
5. (solved by @nuuskur ) Classify all groups of order ##6,8,## and ##12##.
6. (solved by @nuuskur ) Let ##G## be a group of order ##2m## with ##m>1## an odd number. Show that ##G## is not simple, i.e. has at least one non trivial normal subgroup.
7. (a) (solved by @nuuskur ) Show that a group ##G## is abelian if and only the map ##g \mapsto g^{-1}## is a group homomorphism.
7. (b) (solved by @nuuskur ) Suppose that ##G## is a finite group and that we have ##\sigma \in \operatorname{Aut}(G)## with the neutral element ##e## as unique fixed point. If ##\sigma^2=\operatorname{id}_G##, prove that ##G## is abelian.
Hint: Prove that every element of ##G## can be written in the form ##x^{-1} \sigma(x)## and apply ##\sigma## to such an expression.
(Credits will only be given for solving both subquestions.)
8. (solved by @Pi-is-3 ) Show that there is no triple ##(a,b,c) \in \mathbb{Z}^3\setminus \{(0,0,0)\}## such that ##a^2 + b^2 = 3 c^2##.
Hint: Find all squares in ##\mathbb{Z}/4\mathbb{Z}##.
9. (solved by @nuuskur ) Three identical airplanes start at the same time at the vertices of an equilateral triangle with side length ##L##. Let's say the origin of our coordinate system is the center of the triangle. The planes fly at a constant speed ##v## above ground in the direction of the clockwise next airplane. How long will it take for the planes to reach the same point, and which are the flight paths?
10. (solved by @nuuskur ) The Schwarzian derivative of a holomorphic function ##f## is given by
S_f(z)=\{\,f,z\,\} := \dfrac{d}{dz}\left( \dfrac{f^{''}(z)}{f^{'} (z)} \right)-\dfrac{1}{2} \left( \dfrac{f^{''}(z)}{f^{'}(z)} \right)^2= \dfrac{f^{'''}(z)}{f^{'} (z)}- \dfrac{3}{2} \left( \dfrac{f^{''}(z)}{f^{'}(z)} \right)^2
Prove a chain rule for the Schwarzian derivative and show that
\{\,f,z\,\} <0 \,\wedge \,\{\,h,z\,\}<0 \Longrightarrow \{\,f\circ h,z\,\}<0
Schwarzian derivatives are used in dynamical systems to investigate attractors, in flows of surfaces, or in the theory of Schwarz-Christoffel mappings.
11. (solved by @archaic ) Show geometrically that ##\sin^{-1}(\frac{x}{\sqrt{x^2 + 1}}) = \tan^{-1} x## for ##x \geq 0##.
12. (solved by @archaic and @Pi-is-3 ) Give an example of a continuous function ##f(x)## on ##[0,1]## for which the conclusion of Rolle's theorem fails.
Rolle's theorem: If ##f## is differentiable on ##(0,1)## and ##f(0)=f(1)## then there is a point ##c\in (0,1)## such that ##f'(c)=0##.
13. (solved by @etotheipi ) David drives to work every working day by car. Outside towns he drives at an average speed of ##180\,\text{km/h}##. On the
##10\,\text{km}## in town, he drives at an average speed of ##40\,\text{km/h}##. As a result, he is often too fast and gets a ticket. Meanwhile he has realized that things can not go on like this and he decides to reduce his average speed by ##20\,\text{km/h}## in town as well as outside. How long is his way to work, if this reduces his average speed by ##40\,\text{km/h}## on total?
14. Show that ##2x^6+3y^6=z^3## has no other rational solutions than ##x=y=z=0\,.##
15. Let ##x,yz \in \mathbb{R}-\{\,0\,\}## such that
x+\dfrac{y}{z}=2\;\; , \;\;y+\dfrac{z}{x}=2\;\; , \;\;z+\dfrac{x}{y}=2
Show that ##s:=x+y+z## can only have the values ##3## or ##7##.
You do not need to solve the equation system.
  • Wow
Likes YoungPhysicist, Kyle Nemeth, Not anonymous and 3 others
On 13 do you really mean 180km/hr?
Yeah, a bit slow, but for the sake of the exercise it is ok. The problem neglects the acceleration and braking times.
  • Haha
Likes mfb and hutchphd
##f(x)=ax , a\ne 0##
I got the answer as ##e^{-2}##
First, I took derivative of ##x^a e^{2a-x}## and equated it with 0, and got that maximum happens when x=a or when ##f(a)=(ae)^a## . This is ofcourse, not the maximum when a is an even number.
Then, have to find the minimum of ## g(x)=(xe)^x ## for which we use the same procedure to get ##a=e^{-2}##.
Likes QuantumQuest
We know y'' = 2, thus y' = 2x+c.
We know that y' = 10 at (2,6), thus 10 = 2(2)+c, producing y' = 2x+6.
Integrating again we get y = x2+6x + c.
If we choose c to be -16, we get that 2 is a root, so we need to shift up by 6. Thus we need c = -10
Thus y = x2+6x - 10.
Likes QuantumQuest
The hypotenuse would be ##\sqrt{x^2+1}##.
$$\theta=\arcsin{(\frac{x}{\sqrt{x^2+1}})}=\arctan{(\frac{x}{1})}$$
Likes QuantumQuest
This function is strictly increasing or decreasing, thus it does not satisfy the condition that f(a) = f(b) for a≠b on the interval [0,1].
Likes Pi-is-3
Yeah. Sorry, for some reason I read that as f'(a)=f'(b).
Likes KnotTheorist
Strictly speaking your solution was actually one in the sense that one condition is violated and thus the statement doesn't hold any longer.
The more interesting case however is, if ##f(0)=f(1)## holds and differentiability is violated while continuity still holds.
Why is that a more interesting answer than ##f(0)=f(1)## failing? The theorem fails when one or more of its assumptions fails. I guess strictly speaking it may fail, since even if both inputs fail there might still be a place the derivative is zero.
Likes Pi-is-3
fresh_42 said:
1. The maximum value of ff with f(x)=xae2a−xf(x)=xae2a−x is minimal for which values of positive numbers aa ?
Note that for even positive integer values of a, f(x) diverges, so they are not the answer.
Take the derivative of f(x) w.r.t. x. Get this.
f′(x)=e2a(axa−1−xa)e−xf′(x)=e2a(axa−1−xa)e−x
x = a and x=0 give f'(x) = 0. But x=0 will give an inflection point, not a max.
So x=a is the location of the max, and has value aaeaaaea
Q8 is number theory 🙃
##a^2+b^2=3c^2##
##\Rightarrow (a^2+b^2) (\text{mod 4})=3c^2 (\text{mod 4})##
##\Rightarrow (a^2+b^2+c^2) (\text{mod 4})=0##
since ##k^2 (\text{mod 4})## is either ##1## or ##0,## if k is an integer,
##\Rightarrow a=2^{l}x , b=2^{m}y ## and ##c=2^{n}z##
Where ##x,y,z## are not even integers.
##\Rightarrow 2^{2l}x^2+2^{2m}y^2=2^{2n}(3z^2)##
W.L.O.G, we have 2 cases, ##l \leq m,n## or ##n \leq l,m##
If ##l \leq m,n,##
##\Rightarrow## x is even, which is a contradiction.
If ##n \leq l,m##
##\Rightarrow## z is even, which is contradiction.
Hence their are no set of solutions in the set of integers except ##(0,0,0)##
##f(x)=e^{2\pi i x}## :wink:
$$f(x)=|x-\frac{1}{2}|$$
  • Skeptical
Likes QuantumQuest, Pi-is-3 and KnotTheorist
KnotTheorist said:
I am not sure if you are just referring to the Real or Imaginary part of this function, but if the solution is what I am thinking of, I am just positively sure that you a making it too complicated.
I think this is meant for Pi-is-3, right?
Even I think that. He must have misquoted.
It is not differentiable at ##x=\frac{1}{2}##
I am neither referring to the real part, nor the imaginary part. I am taking it as a whole. My function is differentiable at all points, f(1)=f(0) and f'(x) is not 0 between 1 and 0.
Right, for some reason I was thinking of breaking the second assumption. Probably one should look at complex functions, I don't think there's a real function for which Rolle's theorem doesn't hold, since it's a theorem.
Likes Pi-is-3
You are correct. It holds true for all real functions. It is a proved and standard result.
Pi-is-3 said:
##\Rightarrow 2^{2l}x^2+2^{2m}y^2=2^{2n}z^2##
How do you get this? Isn't there a factor ##3## missing on the right?
  • Sad
Likes Pi-is-3
You're right :headbang: . But that doesn't affect the solution luckily. That's because three is not an even number. If the question had 6 instead, then my solution would have been wrong. I got lucky.
Most of my solution is correct, except I forgot to write 3 behind z. Should I retype it (it won't be very difficult, I will quote my answer, edit it and then remove the quote brackets at the end), or is it okay?
Edit: @Math_QED I have edited my answer. I have made an additional change, I messed up the inequality sign too. I have corrected the solution. I think it's correct now.
Here you should specify that ##l,m,n## are non-zero positive integers. This seems important for what follows.
In what follows, you distinguish between two cases. Can you explain why it is enough to consider WLOG only these two cases? (I see why it is sufficient, but other readers may wonder why this is enough).
Also explain how it follows that for example ##x## is even.
I have not solved question 12, there has been a mistake.
Why? We have continuity, ##f(0)=f(1)##, no differentiability at ##x=\frac{1}{2}## and where it's differentiable, it has ##f'(x_0)=\pm 1 \neq 0##.
Likes QuantumQuest
But shouldn't it be differentiable on ##(0,1)##?
If it is differentiable on ##(0,1)##, continuous on ##[1,0]## and ##f(0)=f(1)## then Rolle's theorem guarantees the existence of a point ##x_0\in (0,1)## such that ##f'(x_0)=0##. The theorem is important, since it is used to prove the mean value theorem. (Basically the same with an inclined statement, not only horizontal: ##f'(x_0)=\dfrac{f(a)-f(b)}{a-b}##.)
I do know that, but isn't the question about finding a function that satisfies the assumptions but does not comply to the conclusion? The function I gave fails to meet the differentiability assumption.
  • #31
If a function satisfies all assumptions, then the theorem holds because it is proven. So the conclusion can only fail if an assumption (or all) doesn't hold.
The logic is ##A \wedge B \wedge C \Longrightarrow D## where
A - f is continuous on a closed interval
B - f is differentiable on the interior
C - f has the same value at the starting and the end point
D - there is a point in between with horizontal tangent
  • #32
I was thinking about it in a "give a counter-example" fashion. The question then is rather easy don't you think? I could put forward any function ##f## where ##f(0) \neq f(1)## for example.
  • #33
Let \Sigma be an infinite sigma algebra on a set X, choose \emptyset\subset A_1\subset X and pick for every n\in\mathbb N
<br /> A_{n+1} \in \Sigma \setminus \left ( \left\lbrace\emptyset, X\right\rbrace \cup \left\lbrace\bigcup_{k=1}^mA_k\mid m\leq n\right\rbrace\cup\left\lbrace\bigcap _{k=1}^m A_k^c\mid m\leq n\right\rbrace\right ).<br />
\Sigma is infinite, so we can do this. Put S_n := \bigcup _{k=1}^nA_k\in\Sigma,n\in\mathbb N. Observe that all S_n\subset X.
The sequence S_n^c,n\in\mathbb N, is strictly decreasing. Put
<br /> T_n := S_n^c\setminus S_{n+1}^c\in \Sigma, \quad n\in\mathbb N.<br />
The T_n are pairwise disjoint. The map
<br /> \mathcal P(\mathbb N) \to \Sigma, \quad A\mapsto \begin{cases} \emptyset, &amp;A=\emptyset \\ \bigcup_{x\in A}T_x, &amp;\emptyset\subset A\subset\mathbb N \\ X, &amp;A=\mathbb N \end{cases}<br />
is injective. Note that if A\subset\mathbb N then \bigcup _{x\in A}T_x \subseteq S_1^c \subset X.
  • #34
nuuskur said:
Let \Sigma be an infinite sigma algebra and pick freely A_n\in\Sigma, n\in\mathbb N. Put S_n := \bigcup _{k=1}^n A_k \in\Sigma, n\in\mathbb N. The sequence S_n,n\in\mathbb N, is increasing. Put
<br /> T_1 := S_1 \quad\mbox{and}\quad T_n := S_n\setminus \bigcup _{k=1}^{n-1}S_k\in \Sigma, \quad n\geq 2.<br />
The T_n are pairwise disjoint, thus \Sigma contains at least \mathcal P(\mathbb N) many elements, thus \Sigma is uncountable.
How do you deduce that you have ##\mathcal{P}(\mathbb{N})## elements?
  • #35
Sure. First I'll explain why x is even. Since l is less than equal to m and n, we can divide both the sides by ##2^{2l}## . That in any scenario gives either x is even or x and y are even or all x,y,z are even (when l=m=n) by taking mod 4 both sides. A similar reasoning is followed for z.
As to why it is okay to consider only two cases instead of three (by including the case of m being smaller), considering the case for x is the same as considering the case for y. If it hadn't been the same, I would have to consider 3 cases. I don't know how to explain this one any better. You could think that if (a,b,c) satisfy the equation, then (b,a,c) will also satisfy.
Likes member 587159
  • #36
Why is my formatting disappearing all the time? This is the second time this happened to #33 :mad:
  • #37
I don't know a lot about ##\LaTeX## on this site, but writing the entire answer in a word and then copy pasting helps me a lot. And @fresh_42 advised me to use windows hot keys. That helps a lot. Best part of word is that formatting is preserved.
  • #38
Edited #33 with explanation.
oh lord please have mercy, I don't have the mental capacity required to type mathematical text in word :oops:
  • #39
I'm sorry. I advised it because when I came to this site, I learned that copy pasting latex causes some problems in this website. So I found out alternative ways. It also had the replace function, so I would type shortcuts, and then find and replace them. It also preserved the formatting.
You can also do it in a ##\LaTeX## editor if you want. That's what I did initially.
  • #40
nuuskur said:
Let \Sigma be an infinite sigma algebra on a set X and pick pairwise different A_n\in\Sigma, n\in\mathbb N. Put S_n := \bigcup _{k=1}^nA_k\in\Sigma,n\in\mathbb N. The sequence S_n,n\in\mathbb N is increasing. Put
The T_n are pairwise disjoint, thus \Sigma contains at least \mathcal P(\mathbb N) many elements, thus \Sigma is uncountable. Indeed, the map
is injective.
I'm not convinced this map is injective. It seems that it can happen that ##T_x=\emptyset## and then multiple things get mapped to ##\emptyset##, for example.
For example, if ##A_1 = X## and ##A_2\in \Sigma,A_2\neq X##. Then ##S_1 = S_2 = X## and ##T_2 = \emptyset##. Thus ##\{2\}## and ##\emptyset## get mapped to ##\emptyset##, which violates injectivity.
  • #41
Mhm, good catch. Picking pairwise different \emptyset \subset A_n\subset X gives injectivity.
  • #42
Still won't work. Take for example ##A_1=\{x\}## and ##A_2 =X\setminus \{x\}## (assuming these sets are in the sigma algebra, but this can happen take for example the finite complement sigma algebra). Then ##S_2 =X## and any choice of ##A_3## will lead to ##S_3=X## so ##T_3=\emptyset##.
  • #43
Arghh, I hate these technicalities. We make a decreasing sequence instead inside of a proper subset. The point is that when we have a countable subset of disjoint elements, their generated sub sigma algebra is isomorphic to \mathcal P(\mathbb N) (the T_n correspond to the singletons)
I Changed the picking scheme in #33. You can't pick complements now to make some pathological cases.
  • #44
https://www.physicsforums.com/help/latexhelp/ (short instruction help for PF)
http://detexify.kirelabs.org/symbols.html (additional symbols, some available, some not)
Google: TeX editor (for longer or separate texts) and HotKey (for keyboard programming, e.g. Alt+F for \frac{}{})
  • #45
If I get this right the situation is something like this
As time passes the triangle inside gets smaller and smaller until it vanishes. Call the side length L(t). After \delta t seconds has passed, the new side length would be L(t+\delta t). Apply the cosine law to the triangle EAF which yields
<br /> |FE|^2 = |AF|^2 + |AE|^2 - 2\cos \frac{\pi}{3} |AF||AE| = |AF|^2 + |AE|^2 - |AF||AE|.<br />
i.e
<br /> L(t+\delta t)^2 = (v\delta t)^2 + (L(t) - v\delta t)^2 - (v\delta t)(L(t) - v\delta t).<br />
Rearranging we get
<br /> L(t+\delta t)^2 - L(t)^2 = (3v\delta t - 3L(t))v\delta t<br />
Divide by \delta t and take the limit as \delta t \to 0, thus
<br /> \frac{d}{dt}L(t)^2 = -3vL(t).<br />
Apply the chain rule and we get an initial value problem:
<br /> L&#039;(t) = -\frac{3}{2}v, \quad L(0) = L.<br />
Hence L(t) = L-\frac{3}{2}vt and at t=\frac{2L}{3v} the triangle vanishes.
Likes Pi-is-3
  • #46
Yes, and the flight path (parametrized by time)?
  • #47
i.e
Rearranging we get
Another way of doing this is to notice that since the triangle is always equilateral, the speed in the direction of the center is ##v\cos{30}## and the length to the center is ##l/\sqrt{3}## so ##t=\frac{v\cos{30}}{l/\sqrt{3}}##.
Or you could also think of the distance between two successive points that varies by ##\Delta d \approx -(v\Delta t+v\cos{60}\Delta t)##
Likes Pi-is-3
  • #48
Or you could also think of the distance between two points that varies by ##\Delta d \approx -(v\Delta t+v\cos{60}\Delta t)##
I didn't write the answer for this one, because I didn't really come up with the solution. It was an example question in my physics textbook, and it had 2 methods of solving it. One of them was similar to yours and the other was similar to that of @nuuskur gave.
Likes archaic
  • #49
Oops, I forgot about the trajectory. Well, in short, it's ugly. Actually, this problem is much better in polar coordinates..
Suffices to find explicitly one trajectory. Denote position of plane by (r(t), \varphi (t)), where at t=0 we have r(0) = L and \varphi (0) = 0 (apply translation or reverse traversion later to line up with some initial parameters if necessary).
The plane that is being followed has position (r(t), \varphi (t) + \alpha), where \alpha = \frac{2\pi}{3}. So we get
<br /> \frac{(r\sin \varphi)_t}{(r\cos \varphi )_t} = \frac{r(\sin (\varphi +\alpha) - \sin\varphi)}{r(\cos (\varphi +\alpha) - \cos\varphi)}<br />
which yields (after a while)
<br /> r&#039;\sin\alpha + r\varphi &#039;(\cos\alpha -1) = 0,<br />
i.e
<br /> r&#039; - \sqrt{3}r\varphi &#039; =0\tag{1}<br />
The flight speed is constant so we have
<br /> v^2 = (r\sin\varphi)_t^2 + (r\cos\varphi)_t^2 = r&#039;^2 + r^2\varphi &#039;^2 \tag{2}<br />
From (1) and (2) we get r&#039; = \frac{\sqrt{3}}{2}v sooo I think I have calculated incorrectly somewhere. Let's roll with it for now. Anyway, the angle is given by (1) and (2) as
<br /> \varphi &#039; = \frac{v}{2r} = \frac{v}{2L - \sqrt{3}vt} \implies \varphi (t) = \int \frac{v}{2L-\sqrt{3}vt}dt = - \frac{\sqrt{3}}{3} \ln |2L-\sqrt{3}vt| + C<br />
where C = \frac{\sqrt{3}}{3} \ln 2L
I think I made a calculation error somewhere, too tired to (double check) ^{10} right now.
  • #50
Suffices to find explicitly one trajectory. Denote position of top plane by (r(t), \varphi (t)), where at t=0 we have r(0) = L and \varphi (0) = 0 (apply translation or reverse traversion later to line up with some initial parameters if necessary).
i.e
I think it's ok more or less. I don't have time now to check in detail either.
In my version, the ugly parts are simply initial conditions and then it doesn't look ugly at all:
To get the flight path we decompose ##\vec{v}(t)## in components parallel and perpendicular to ##\vec{r}(t).## The perpendicular component is ##|v_\perp| = v\cdot \sin \psi = \dfrac{v}{2}## so we have the angular velocity ##\dot{\omega}(t)=\dfrac{v_\perp (t)}{r(t)}.## We parameterize the motion by cylindric coordinates ##\vec{r}(t)=(r(t)\cos \varphi(t)\, , \,-r(t)\sin \varphi(t)\, , \,0)^\tau## and receive the momentary rotation angle by the integration
\begin{align*}
\varphi(t)&=\varphi(0) + \int_0^t \omega(t')\,dt'\\
&=\varphi(0)+ \dfrac{v}{2} \int_0^t \dfrac{1}{r(t')}\,dt'\\
&=\varphi(0)+ \dfrac{v}{2} \int_0^t \dfrac{1}{\frac{L}{\sqrt{3}}-v\frac{\sqrt{3}}{2}t'}\,dt'\\
&= \varphi(0)+ \int_0^t \dfrac{1}{\dfrac{2L}{\sqrt{3}v}-\sqrt{3}t'}\,dt'\\
&=\varphi(0)+ \dfrac{1}{\sqrt{3}}\int_0^t \dfrac{1}{\frac{2L}{3v}-t'}\,dt'\\
&=\varphi(0)+ \dfrac{1}{\sqrt{3}} \log\left( \dfrac{\frac{2L}{3v}}{\frac{2L}{3v}-t} \right)\\
&=\varphi(0)+\dfrac{1}{\sqrt{3}} \log\left( \dfrac{r(0)}{r(t)} \right)
\end{align*}
so the flight path is the logarithmic spiral with
r(t) = r(0)\cdot e^{-\sqrt{3}\left( \varphi(t)-\varphi(0) \right)}
The distance towards the center decreases by a factor of ##e^{-2\pi \sqrt{3}}\approx 1.88 \cdot 10^{-5}## with every complete turn.
Likes Pi-is-3 and nuuskur
16K
10K
11K
15K
11K
11K
9K
10K
10K
11K
