Math Challenge - June 2021
61 replies · 13K views · last reply
julian said:
Problem #8:
By definition
\begin{align*}
H (p) = 1 + \frac{1}{2} + \frac{1}{3} + \cdots + \frac{1}{p -1} = \frac{a}{b} .
\end{align*}
If we can show that:
\begin{align*}
(p - 1)! \left( 1 + \frac{1}{2} + \frac{1}{3} + \frac{1}{4} + \frac{1}{5} + \frac{1}{p - 1} \right) = k p^2
\end{align*}
where ##k## is an integer then we would have
\begin{align*}
H (p) = \frac{k p^2}{(p - 1)!} .
\end{align*}
Since none of the factors in ##(p - 1)!## divide ##p## no ##p## in the numerator can be canceled out. Thus ##p^2## would divide the numerator.
In the polynomial
\begin{align*}
g (x) = (x-1)(x-2) \cdots (x - (p - 1)) = x^{p-1} + a_1 x^{p - 2} + \cdots + a_{p -2} x + a_{p - 1} \quad (*)
\end{align*}
the term ##a_{p - 2}## is given by
\begin{align*}
a_{p -2} = - (p -1)! \left( 1 + \frac{1}{2} + \cdots + \frac{1}{p - 1} \right)
\end{align*}
If we can show that ##- a_{p - 2} = k p^2## that will solve the problem.
We have ##a_{p - 1} = (p - 1)!##.
Fermat's little theorem says that ##a^{p - 1} \equiv 1 \; (\text{mod } p)## for any integer ##a##. It follows that modulo ##p##, that ##x^{p - 1} - 1## has the roots ##p - 1## roots ##1,2, \dots , p-1##. So that:
\begin{align*}
h (x) = x^{p - 1} - 1 \equiv (x-1)(x-2) \cdots (x - (p - 1)) \; (\text{mod } p) .
\end{align*}
Note that modulo ##p##, ##h (x)## and ##g (x)## have the same roots.
Also, Wilson's theorem says that:
\begin{align*}
(p - 1)! \equiv -1 \; (\text{mod } p)
\end{align*}
Using all of the above in the polynomial ##g (x) - h (x)## we obtain
\begin{align*}
f (x) & = g (x) - h (x)
\nonumber \\
& = x^{p-1} + a_1 x^{p - 2} + \cdots + a_{p -2} x + a_{p - 1} - x^{p - 1} + 1
\nonumber \\
& \equiv a_1 x^{p - 2} + a_2 x^{p -3} + \cdots + a_{p -2} x \; (\text{mod } p)
\nonumber \\
& \equiv 0 .
\end{align*}
As this is a polynomial of degree ##p - 2## with the ##p - 1## solutions by Lagrange's theorem ##p## divides all the coefficients.
Putting ##x = p## in ##(*)## gives
\begin{align*}
(p-1)! = p^{p-1} + a_1 p^{p - 2} + a_2 p^{p -3} + \cdots + a_{p -2} p + a_{p - 1}
\end{align*}
Subtracting ##(p - 1)!## from both sides, dividing by ##p##, and then rearranging gives
\begin{align*}
- a_{p - 2} = p^{p-2} + a_1 p^{p - 3} + \cdots + a_{p - 3} p .
\end{align*}
As we are taking ##p \geq 5##, and as each of the coefficients ##a_1, a_2, \dots a_{p - 3}## is proportional to ##p## the RHS is equal to ##k p^2## where ##k## is an integer.
If ##p## were equal to 3 we couldn't say that the term ##a_1 p^{p - 3}## is proportional to ##3^2## as ##a_1 p^{p - 3} = a_1##. The result clearly doesn't apply to ##H (3)##:
\begin{align*}
H (3) = 1 + \frac{1}{2} + \frac{1}{3} = \frac{11}{6} .
\end{align*}
Right. The result is known as the Theorem of Wolstenholme.
julian said:
Problem #6:
By definition
\begin{align*}
d = \min_{(x,y) \in C^2 , x \not= y} d (x,y)
\end{align*}
where ##d(x,y)## be the Hamming distance of ##x## and ##y##. A bound is proved by bounding the quantity
\begin{align*}
\sum_{(x,y) \in C^2 , x \not= y} d (x,y)
\end{align*}
in two different ways. On the one hand, there are ##\# C## choices for ##x## and for each such choice, there are ## \# C - 1## choices for ##y##. Since by definition ##d (x,y) \geq d## for all ##x## and ##y## (##x \not= y##), it follows that
\begin{align*}
\sum_{(x,y) \in C^2 , x \not= y} d (x,y) \geq \# C (\# C - 1) d .
\end{align*}
The other inequality is obtained by writing down all the ##\# C## codewords of ##C## into a ##\# C \times n##-matrix. Let ##n_{i , \alpha}## denote the number of times the element ##\alpha## of the alphabet (with ##q## elements) occurs in the ##i##th column. For each choice of ##\alpha## in the ##i##th column there are ##\# C - n_{i , \alpha}## elements not equal to ##\alpha## in the same column. Then
\begin{align*}
\sum_{(x,y) \in C^2 , x \not= y} d (x,y) & = \sum_{i = 1}^n \sum_{\alpha} n_{i , \alpha} (\# C - n_{i , \alpha})
\nonumber \\
& = \sum_{i = 1}^n \left( (\# C)^2 - \sum_\alpha n_{i , \alpha}^2 \right) \qquad ( \sum_{\alpha} n_{i , \alpha} = \# C)
\nonumber \\
& \leq \sum_{i = 1}^n \left( (\# C)^2 - \frac{(\# C)^2}{q} \right) \qquad ( (\# C)^2 = (\sum_{\alpha} n_{i , \alpha} \cdot 1)^2 \leq (\sum_{\alpha} n_{i , \alpha}^2) (\sum_{\alpha} 1^2) )
\nonumber \\
&= n \cdot (\# C)^2 \cdot \left( 1 - \frac{1}{q} \right) .
\end{align*}
Combining the two bounds gives
\begin{align*}
\# C (\# C - 1) d \leq (\# C)^2 \cdot n \cdot \left( \frac{q - 1}{q} \right)
\end{align*}
or
\begin{align*}
d (\# C - 1) \leq \# C \cdot n \cdot \left( \frac{q - 1}{q} \right) \qquad (*)
\end{align*}
If ##d < n \cdot \dfrac{q - 1}{q}## the bound ##(*)## can be rearranged as
\begin{align*}
\# C \leq \frac{d}{d - n \cdot \dfrac{q - 1}{q}} .
\end{align*}
The bound is called Plotkin bound.
