Solving Functions f and g: Range and Relationship with Homework Statement
  • Thread starter Thread starter WeiLoong
    Functions
The discussion centers on solving for the range of functions f and g without differentiation and proving that f(x)^2 + g(x)^2 = 1. For part a, one participant attempted to find the range of f using limits, concluding that x includes all real numbers, but was reminded that they should focus on the function values instead. In part b, participants discussed the need to expand the squared functions and showed that the sum of their squares equals one, indicating a relationship between f and g. The conversation emphasizes understanding the behavior of f and g through limits and algebraic manipulation. Overall, the thread highlights the importance of correctly interpreting the problem requirements and applying mathematical principles to find solutions.
WeiLoong
The functions f and g are given by
https://scontent-kul1-1.xx.fbcdn.net/hphotos-xtf1/v/t35.0-12/11993948_10204837479208369_1887096410_o.jpg?oh=b1653a61128c571af8137b1fd00ccb01&oe=55F47BC4
a) without using differentiation, find the range of f
b)show that f(x)^2+g(x)^2=1.Hence find the range of g.
FUnction
[/B]
for question A i used limit to infinity so that the function can be a number, thus I got x=all real number if i use limit to infinity. for question B i have no clue. please help
I agree. f and g are both defined for all real values of x.
For problem b, what do you get when you square these functions?
what is [f(x)]^2, what is [g(x)]^2?
Note that they both have the same denominator, so you need to show that the sum of the squared numerators is equal to the square of the common denominator.
Do you know what ##(e^x)^2 ## is?
Do you know what ##( a + b) ^2 ## is ?
If you know those rules, this just needs to be expanded out to show the answer.
FUnction
[/B]
Part a asks for the range -- the set of function values -- not the domain.
For ##\lim_{x \to \infty}f(x)##, what did you get? Also, you might want to look at the limit as x approaches -∞. These limits might give you an idea about the behavior of f.
Did you try part b? It asks you to show that ##(f(x))^2 + (g(x))^2 = 1##. They have told you what the answer should be.
This isn't relevant, though, as the problem asks for the range of f, not the domain.
Likes RUber
Since e^x is positive for all x, \frac{e^x- e^{-x}}{e^x+ e^{-x}} is a fraction with the numerator smaller than the denominator.
