Mathematica Mathematica: Discrete Fourier Transform
The discussion revolves around performing a Fourier Transform on a discrete function F using Mathematica. The user encounters an issue where the output only contains real numbers without any apparent phase information. Clarification is provided on how Mathematica computes the discrete Fourier Transform (DFT) using a specific formula, which results in complex numbers representing both amplitude and phase. The conversation highlights that the phase can be derived from the imaginary and real parts of the DFT output using the ArcTan function, allowing the user to extract the phase angles corresponding to each frequency component. The importance of understanding both magnitude and phase in Fourier analysis is emphasized, with suggestions to further explore Mathematica's documentation for additional insights.
Niles
Hi all
I have a function F, which depends on a discrete variable x, and I need to Fourier Transform it. I have put all the values of F in a table.
Then I have used the command "Fourier" on the table, which - according to http://reference.wolfram.com/mathematica/ref/Fourier.html - results in the discrete Fourier Transform. But the new table only contains pure numbers, no phase factor. Why is that, and is there a way to include the phase?
Niles.
Does anybody know this? I feel bad "bumping" the thread, but I am in real trouble if I can't work this out.
Post the relevant code.
Here you go (the values of F are in the table)
Code:
four = Fourier[{0.5,1.0,3.0,5.0}]
Mathematica {4.75+0 i,-1.25-2. i,-1.25+0 i,-1.25+2. i}
Why not {9.50 + 0 i, -2.50 + 4. i, -2.50 + 0.i, -2.50 - 4.i} ?
But I really don't know what it is that Mathematica is calculating? The amplitudes or what?
Hi Niles. It's easy to see what Mathematica is computing. Just do a help on Fourier and hit the more info button. For a list {u_n}, Mathematica creates a list {v_n} such that:
v_s=\frac{1}{\sqrt{n}}\sum_{r=1}^n u_r e^{2\pi i(r-1)(s-1)/n}
so for your list {0.5, 1.0, 3.0, 5.0},
the first value computed by Mathematica is:
v_1=\frac{1}{\sqrt{n}}\sum_{r=1}^n u_r e^{2\pi i(r-1)(1-1)/n}=4.75
Don't know what you mean by phase factor or amplitude though. Try reading through all the various options in the More info. Maybe you'll spot something that can help you.
I will have to think about this. Thanks!
If x(n) represents the time-domain data, the formula for an N-point discrete Fourier transform is given by
<br /> X(m) = \sum_{n=0}^{N-1} x(n) e^{-2\pi imn/N}, \qquad m=0\ldots N-1.<br />
You'll often be interested in the magnitude and power contained in each X(m). If you represent an arbitrary DFT output value, X(m), by its real and imaginary parts:
<br /> X(m) = X_\textrm{real}(m) + iX_\textrm{imag}(m) = X_\textrm{mag}(m) \textrm{ at an angle of }X_\theta(m)<br />
the magnitude of X(m) is simply
<br /> X_\textrm{mag}(m) = |X(m)| = \sqrt{X_\textrm{real}(m)^2 + X_\textrm{imag}(m)^2}.<br />
The phase angle of X(m) is then defined by
<br /> X_\theta(m) = \tan^{-1} \left(\frac{X_\textrm{imag}(m)}{X_\textrm{real}(m)}\right).<br />
Therefore, if you calculate the DFT of your data as
Code:
 In[1]:= four = Fourier[{0.5,1.0,3.0,5.0}]
Out[1]:= {4.75 + 0. I, -1.25 - 2. I, -1.25 + 0. I, -1.25 + 2. I}
the phase is obtained simply as
Code:
 In[2]:= phases = ArcTan[Im[four]/Re[four]]
Out[2]:= {0., 1.0122, 0., -1.0122}
Is that what you're looking for?
I will try and experiment with it; I'll keep you posted. Thanks so far.
