How can I solve an equation with an integral in MATLAB?
In summary, the user is looking for help with solving integrals involving the Fermi-Dirac distribution using MATLAB. They have attempted to use various methods, but have encountered errors. They are seeking guidance on how to properly write a function for solving such integrals.
_Matt87_
hi people,
I've just recently started using MATLAB (last week) and 've already got plenty of problems. Could anyone help me with this for example [??]:
1)
3=∫(0,inf) (sqrt(ε)/exp[(ε-μ)/(8*T)] dε
so this is the equation. I would like to solve in a way that μ=... , and then plot the μ(T) with T=0:1:10000;
2)
f=∫(-inf,inf) d[ 1/{exp[(ε-μ)/(8*T)]+1} ]/dT
where μ is a functions from the previous. and there is a partial derivative with respect to T.
also plot it as f(T).
1) Use the function arrayfun:
Code:
I = @(u) arrayfun(@(mu) integral(@(e) sqrt(e).*exp(-e+mu),0,inf),u);
This solves the integral for whatever values are specified in u. Analytically, we know that
[tex]I =8T \int_0^{\infty} \frac{\sqrt{\epsilon}}{e^{\epsilon - \mu}} d\epsilon = \frac{8T\sqrt{\pi}}{2}e^{\mu}[/tex]
So plotting I is kind of boring since it is just an exponential.
Solving for mu tells us that
[tex]\mu(T) \approx \ln \left( \frac{I(\mu)}{T} \right)[/tex]
2) Use Leibniz's Integral Rule: http://en.wikipedia.org/wiki/Leibniz_integral_rule
that 8T is actually under the exp- like that:
[tex]I=\int_{0}^{inf} dε \frac{\sqrt(ε)}{\exp(\frac{ε-μ}{8T})}[/tex]
does it make a big difference? or I just add it to the code?
and what would the analitical solution be?
[tex]\begin{align}\int_{0}^{inf} dε \frac{\sqrt(ε)}{\exp(\frac{ε-μ}{8T})}&= \int_{0}^{inf} dε \sqrt(ε) \exp(-\frac{ε-μ}{8T})\\ &= \int_{0}^{inf} ε^{1/2}\, \exp(\frac{-ε}{8T}) \exp(\frac{μ}{8T})\, dε\\&= \exp(\frac{μ}{8T}) \int_{0}^{inf} ε^{1/2}\, \exp(\frac{-ε}{8T})\, dε \end{align}[/tex]
Now substitute
[tex] t := \frac{ε}{8T} [/tex]
and deploy the integral form of the Γ- function, like kreil did above.
all right. that seems easy. but what if the integral looked like that? (and I wanted to solve it by matlab?):
[tex]I=\int_{0}^{inf} dε \frac{\sqrt(ε)}{\exp(\frac{ε-μ}{8T})+1}[/tex]
_Matt87_ said:
[...]but what if the integral looked like that? (and I wanted to solve it by matlab?):
What have you yet tried to solve that problem on your own?
ok ok
I started with something like that:
Code:
function u= chempot
k=1.380648813e-23;
u0=7.370012199e-19;
I=@(e,T,u) sqrt(e)/(exp((e-u)/(k*T))+1);
    II=integral(I,0,inf);
for T=1:1:10000
    x0=[-10*u0];
    u=fsolve(@(u) 2*u0^(3/2)/3-II,x0);
    plot(T,u)
    hold on
end
doesn't work. plenty errors, don't know what's going on.
is that 'integral' function actually integrate over e?/////
on the second thought it maybe should look more like this:
Code:
function u = proba(T)
k=1.380648813e-23;
u0=7.370012199e-19;
    u=fsolve(@(u) 2*u0^(3/2)/3-II,u0);
with temperature being set from outside of the function. It still doesn't work though :(
hi all! I've got something!
Code:
k=1.380648813e-23;
u0=7.370012199e-19;
options=optimset('TolFun',1.0e-16,'TolX',1.0e-16);
u=fsolve(@(u)(2*u0^(3/2)/3-quad(@(e)(sqrt(e)./(exp((e-u)./(k.*T))+1)),0,1000000,1e-20)),u0,options);
plot(T,u);
hold on
end
only that it doesn't work :) but it's very close.
I open the function in a loop for T=1:1:10000
but! the numbers seem to be too small for 1) quad 2)fsolve.
so that quad (or 'integral') gives 0. and whole fsolve give just the constant value of u0.
Could anyone help me now with it? as We're so close to the solution ?
It should be giving a curve like the one in the picture below for Three dimensions (I found it here http://www.lcst-cn.org/Solid%20State%20Physics/Ch63.html ) where ef is my u0 and x-axis should be temperature T.
http://www.lcst-cn.org/Solid%20State%20Physics/Ch63.files/image010.gif
OK, that looks like work.
But before I consult Matlab, Maple, Maxima etc vX.Y I tend to consult Brain v1.0 and a good integral table
Afais this
[JZ07]/3.411.3 said:
[tex] \int_0^\infty \frac{x^{\nu-1}}{e^{\mu x} + 1}\, dx = \frac{1}{\mu^\nu} \left(1 - 2^{1-\nu}\right) \Gamma(\nu) \zeta(\nu)\qquad \left[\Re(\mu) > 0, \Re(\nu)> 0 \right] [/tex]
could be useful.
Regards, Solkar
[JZ07] Jeffrey, A. & Zwillinger, D. Table of Integrals, Series, and Products. Elsevier Science, 2007
Thank you.
Only that I am in the same time trying to learn Matlab. And as I've got some other functions similar to mentioned, which I need to solve numerically, I would need someone just to tell me how to write a proper function for that. Or at least tell me why the one I put before do not work?
as for the Table of Integrals. Could you tell me what is [tex]\zeta(\nu)[/tex]?
@kreil
The
exp(-µ/kT) (=: C)
part in the denominator is the main burden.
What do you thing about simply replacing this with i and then picking Im() of the result after plain complex-valued numerical integration?
What could hurt?
I should have guessed this is what the integral actually was. It's the Fermi-Dirac distribution.
I recommend using this m-file I found on the exchange and editing it to meet your needs.
http://www.mathworks.com/matlabcentral/fileexchange/13616-fermi
1. What is the syntax for writing an integral equation in MATLAB?
The syntax for writing an integral equation in MATLAB is: int(function, variable, lower limit, upper limit). The function can be a symbolic expression or a MATLAB function, and the limits can be numbers or symbolic variables.
2. How can I solve an integral equation in MATLAB?
To solve an integral equation in MATLAB, you can use the int function along with the solve function. The int function will calculate the integral, and the solve function will find the values of the unknown variables in the equation.
3. Can I plot an integral equation in MATLAB?
Yes, you can plot an integral equation in MATLAB by using the ezplot function. This function allows you to plot symbolic expressions, including integral equations, over a specified range of values.
4. How do I set the accuracy of the integral calculation in MATLAB?
You can set the accuracy of the integral calculation in MATLAB by using the digits function. This function allows you to specify the number of digits MATLAB will use for calculations, including integrals.
5. Are there any built-in functions in MATLAB for solving differential equations with integrals?
Yes, there are several built-in functions in MATLAB for solving differential equations with integrals. Some of these functions include ode15i, ode23tb, and ode23t. These functions use different numerical methods to solve differential equations with integrals and provide accurate results.
