MATLAB How can I use MATLAB to take the derivative of an experimental plot?
  • Thread starter Thread starter lcr2139
    Matlab Mean
In MATLAB, the operator "./" represents element-wise division, allowing for the division of corresponding elements in two arrays or vectors. For example, using "x = [1:10]" and "y = [1:0.5:5]", the expression "x ./ y" divides each element of x by the corresponding element of y. To take the derivative of an experimental plot in MATLAB, the "diff" function can be used to compute the differences between consecutive data points, which can then be divided by the differences in the x-values to approximate the derivative. For integration, the "trapz" function is commonly used for numerical integration of data points. To subtract two experimental plots, the same element-wise division operator "./" can be applied, allowing for the subtraction of corresponding elements in two datasets.
lcr2139
In MATLAB, what does ./ mean?
Also, I would like to take the derivative of an experimental plot. How do I do so?
Also, how do you integrate it?
Also, how do you subtract two experimental plots from each other?
Its used to pair elements of a vector together to divide them.
As an example, try this:
Matlab:
x = [ 1 : 10 ]
y = [ 1 : 0.5  : 5 ]
x ./ y
It divides each element of x by an element of y
or this
Matlab:
x = [ 0  : 0.1 : 10 ]
y = x .* x
plot( x , y )
squares each element of x and plots a parabola x vs y chart
