Matrices and number of solutions
  • Thread starter Thread starter t_n_p
    Matrices
For the first question, the value of 'a' that results in infinitely many solutions is determined to be 0, as it leads to dependent equations where one can be expressed as a multiple of another. When 'a' is set to 2, the equations yield no solutions due to inconsistencies. In the second question, the value of 'p' that allows for more than one solution is found to be 3, as it makes the determinant of the coefficient matrix equal to zero, indicating dependence among the equations. The discussion emphasizes the importance of understanding determinants and the conditions for infinite solutions in systems of equations. Overall, the analysis highlights the relationship between coefficients and the nature of solutions in linear systems.
t_n_p
Q1. Find the value of a for which there are infinitely many solutions to the equations
2x + ay − z = 0
3x + 4y − (a + 1)z = 13
10x + 8y + (a − 4)z = 26
Now I know that for there to be infinitely many solutions the determinant of the coefficient matrix must = 0.
I did this on a calculator and found 2 possibilities, 0 and 2.
Additionally, I know that there are infinitely many solutions when 2 of the equations are indentical (by a factor). By trying both 0 and 2 I cannot see how any of the 2 equations will be identical. (Apparently the answer is a=0)
Q2. Find a value of p for which the system of equations
3x + 2y − z = 1 and x + y + z = 2 and px + 2y − z = 1
has more than one solution.
Not sure where to start here, more than one solutions hints at what?
Actually, infinitely solutions exist for your system when the system of equations is dependent, and for three equations, this means that anyone equation can be written as a linear combination of the other two. For example, if you set a=2, then 8 times the first equation plus -2 times the second equation results in the third equation. I figured this out by doing something like this:
b(2x+2y-z) + c(3x+4y-3z) = 10x+8y-2z = (2b+3c)x + (2b+4c)y + (-b-3c)z
We know that the x components are equal, the y components are equal, and the z components are equal. This, we can prove that b=8 and c=-2. It's easy to prove something similar for a=0. Thus, the system of equations is dependent, and there is more than one solution.
For your second question, have you learned yet about augmented matrices and elementary row operations?
For the first question, I just wish to find the value of a for which there are infinitely many solutions. The answer actually specifies a=0 alone, rather than a = 0 or a = 2. So I'm wondering how they eliminate a = 2.
For second question:
more than one solution means det = 0
det of the coefficient matrix is 3(p-3)
thus 3(p-3) = 0, p = 3
hope its as simple as that
If the determinant of the coefficient matrix is not 0 there is a unique solution. If is is 0, there are either an infinite number of solutions or no solution.
It's easy to see that if a= 0, then the equations become
2x − z = 0
3x + 4y − z = 13
10x + 8y − 4z = 26
Of you multiply the second equation by 2 and subtract that from the third equation you get 4x- 2z= 0 which is just a multiple of the first equation. That's why a= 0 gives an infinite number of solutions. You can choose x to be any number at all, take z= 2x, y= (13- x)/4 and you have a solution.
If a= 2 the equations become
2x + 2y − z = 0
3x + 4y − 3z = 13
10x + 8y − 2z = 26
Now, if you multiply the second equation by 2 and subtract that from the third equation you get 4x + 4z= 0. If you multiply the first equation by 2 and subtract that from the second equation you get -x- z= 13. No values of x and z make both of those equations true. That's why there is no solution.
If you wanted to do this with matrices, you could write the "augmented matrix",
\begin{bmatrix}2 & a & -1 & 0\\ 3 & 4 & -(a+1) & 13\\ 10 & 8 & a- 4 & 26\end{bmatrix}
and row reduce. If a= 0, the resulting reduced matrix will have all "0"s in the last row. If a= 0, the last row will have "0"s in the first three columns but not in the fourth column.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
