Max P.S.I. at Bottom of Pipe with 60' Drop?
  • Thread starter Thread starter acschier
    Pipe
A vertical drop of 60 feet will generate pressure at the bottom of the pipe based solely on that height, regardless of whether a 2" or 4" pipe is used. The larger pipe reduces flow resistance and energy loss once water begins moving, but does not affect the pressure generated by the drop. To maintain efficiency, the flow rate should be managed to keep the water velocity below about 5 feet per second. The pressure can be calculated using the formula p = 0.433h, where h is the height in feet and p is the pressure in psi. Understanding these factors will help optimize the setup for running a water wheel or turbine effectively.
acschier
To keep it simple: I have a vertical 60 foot drop. I want to create the maximum P.S.I. at the bottom of the pipe possible to run a water wheel or a turbine. If the bottom hole (say 2") and the vertical drop of two pipes is the same will there be a difference in a 4" or a 2" pipe? Note: there would be a small dam at the top to fill the pipe to maximum capacity. Also, is there a formula to easily figure out P.S.I. using drop height, water area and weight including the limiting factor of the bottom hole? Thanks!
(I am only a Physics 12 grad so keep it simple) :smile:
Welcome to PF.
The larger the pipe, the lower the resistance to flow (and loss of energy) once the water starts moving, but otherwise, no: the pressure at the bottom of the pipe is dictated by the vertical drop alone. So you'll want to figure out how much flow rate you have available and make sure the pipe can handle it without too much loss (keep it below about 5 fps velocity), but otherwise pipe size doesn't matter much. The formula is p=.433h (h is height in feet, p is pressure in psi).
Thank you very much, that's exactly what I needed!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Someone who shows interest in science is initially a welcome development. So are fresh ideas from unexpected quarters. In contrast, there is a scientific community that is meticulously organized down to the last detail, allowing little to no external influence. With the invention of social media and other sites on the internet competing for content, unprecedented opportunities have opened up for...
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
