Max Space Velocity: Reach Limit?
The discussion centers on the theoretical limits of spacecraft velocity, specifically the concept that the maximum velocity approaches the speed of light (c) but cannot reach it. As a spacecraft accelerates, its effective mass increases, requiring exponentially more force to continue accelerating. Consequently, even with a powerful engine, as the spacecraft nears c, the acceleration diminishes toward zero. The type of propulsion system, such as ion thrusters, plays a crucial role in determining the spacecraft's ability to achieve high velocities. Ultimately, while theoretical limits exist, practical constraints significantly impact actual acceleration and velocity.
mpekatsoula
Ok.. first of all excuse my English (not my native).
I had a conversation with a friend and we were thinking.. We have a spacecraft or something like that. Let's tell that it has a lot of fuel and we are moving with a = x m/s^2, where a is acceleration and x a value (we don't care how big or small). What is the MAX velocity that we will go with? Theoretically v-->c (no abrasion with something wright?), but obviously that's not possible. What is going to make our spacecraft move with a max velocity and what's that value?
Thanks
The max theoretical velocity you can obtain is very close to c, the closer you get to c the larger force you will need to obtain your acceleration. Let's say that you want to maintain constant your acceleration to x m/s^2 then the real problem is that (not taking in account any feasibility of it)
a = F/M where F is the force applied and M is your mass
but the faster you go the larger is your mass that means that the faster you go the larger the force you need to apply to your spacecraft to accelerate.
What will happen, considering that you have engine powerful enough, is that the closer you get to c the smaller your acceleration will be (going to the limit at 0)
Regarding what is going to make your spacecraft moving, that depends on the engine you have.
You can have normal thrust, but probably they will fail to accelerate you beyond a certain point, you can have ion thrusters or any other propulsion system you can imagine. There are many type of hypothetical engine that go from ion thrusters (see on wikipedia how they work) I suggest you to give a look to http://en.wikipedia.org/wiki/Spacecraft_propulsion
Thanks AGADOTTI! obvious i can tell but i couldn't think that this was the reason! thanks for the link also
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
