Maximising sensitivity in a voltage divider
The discussion centers on maximizing the sensitivity of a voltage divider circuit, specifically a resistive divider with a fixed resistor R1 and a variable potentiometer R2. The key conclusion is that the sensitivity, defined as the range of output voltage (Vo), is maximized when R2 is set to half the range of its resistance (ΔR2). The equations governing the voltage divider, including Vo = (Vi * R2) / (R1 + R2), are critical in deriving this result. Participants also explored the implications of setting R1 equal to R2, clarifying that while it offers power transfer benefits, it does not maximize sensitivity.
  • Understanding of voltage divider circuits and their components
  • Familiarity with basic calculus, particularly differentiation
  • Knowledge of electrical power calculations, including P = I^2 * R
  • Concept of sensitivity in electrical circuits
  • Study the principles of voltage dividers in depth, focusing on resistive dividers
  • Learn advanced calculus techniques for maximizing functions
  • Explore the relationship between resistance and power transfer in electrical circuits
  • Investigate practical applications of potentiometers in circuit design
Electrical engineers, students studying circuit design, and hobbyists working with voltage dividers and potentiometers will benefit from this discussion.
iainfs
Hi folks,
We have a voltage divider (more specifically, a resistive divider), with V_i volts input and resistors R_1 and R_2 in series. The output voltage, V_o, is measured over R_2. R_1 is a fixed ohmic resistor; R_2 is a potentiometer. I'm looking for an algebraic proof that, for a constant V_i and given range of resistances on R_2, the sensitivity (range of V_o) is maximised when the middle range of R_2 = R_1.
I have read this in a textbook but have yet to be satisfied by a proof!
Well, I suppose we have V = IR and V_o = \frac{V_i \cdot R_2}{R_1+R_2}.
I've guess that this requires calculus, which I should be OK with as long as we don't get into anything too complicated. I'm not entirely sure how to approach this, but I'll give it a shot anyway!
As far as I can see, I want to maximise the rate of change of V_o with respect to R_2.
\frac{dR_2}{dV_o}\;({\frac{V_i \cdot R_2}{R_1+R_2}})
I can't differentiate that because I don't know how. The constant seems to be all wrapped up with the variable. Some help here would be appreciated.
I would then go on to maximise this by finding \frac{d^2V_o}{d{R_2}^2}\;({\frac{V_i \cdot R_2}{R_1+R_2}}) = 0; hopefully solving the problem.
As you can see, I think I have a viable method, but I'm not able to follow it through. Any help would be greatly appreciated!
Many thanks,
the sensitivity (range of ) is maximised
I think you need to define what you mean by the "sensitivity (range of)" means. You get the max range when the R2 potentiometer is much larger than R1, so that the output voltage ranges from almost Vin to zero.
You would get some power transfer benefits if you size R2 = R1, but so far I don't see that entering into the question...
Thanks for your reply.
Yes, that would make sense. I think I have been misled as to the benefits of R1 = R2. For pure sensitivity (volts/ohm), a very large pot is best.
What, then, are the benefits of R1 = R2?
Many thanks.
Many thanks.
Calculate the power transferred to R2 in terms of the ratio of R2:R1. Do you see anything useful?
I'm sorry, I'm struggling with that one. Do you mean power as would be given by P = I^2 x R?
Another possible point of confusion I have noticed is that a common type of potential divider has R1 + R2 = constant = the total resistance on the potentiometer. Mine uses a fixed resistor for R1; R2 is a variable resistor.
I had another attempt. Still no joy unfortunately.
I = \frac{V_i}{R_1+R_2}
I^2 = \frac{V_i^2}{(R_1+R_2)^2}
P_{R_2} = I^2R = \frac{V_i^2 \cdot R_2}{(R_1+R_2)^2}
Alternatively, using P = VI:
P = V_oI = \frac{V_i^2 \cdot R_2}{(R_1+R_2)^2}
which gives the same. I can't seem to get it in terms of a ratio R1:R2. Assistance would be appreciated because it's driving me nuts!
This is a strange problem, and I wonder when you would ever encounter it in practice. Anyway ...
Let's call the range in in pot resistance as \Delta{}R_2. And, let's call the middle of this range simply R_2. So, the range in the output voltage, as a function of the middle of the pot range, is
<br /> \Delta{}V_o\left(R_2\right)<br /> =<br /> V_o^{hi}-V_o^{lo}<br /> =<br /> V_i\frac{R_2+\frac{1}{2}\Delta{}R_2}{R_1+R_2+\frac{1}{2}\Delta{}R_2}<br /> -<br /> V_i\frac{R_2-\frac{1}{2}\Delta{}R_2}{R_1+R_2-\frac{1}{2}\Delta{}R_2}<br /> =<br /> V_i\frac{R_1\Delta{}R_2}{\left(R_1+R_2\right)^2-\frac{1}{4}\Delta{}R_2^2}<br />
We are looking for the maximum \Delta{}V_o w.r.t. R_2. This looks like a resonance bump with a resonance at R_2=-R_1. I will check my work again.
UPDATE: Ah. It is not in the shape of a resonance bump, at least not w.r.t. R_2.
I conclude that \Delta{}V_o is maximized w.r.t. R_2, for given \Delta{}R_2, R_1, and V_i, when R_2=\frac{1}{2}\Delta{}R_2.
  • · Replies 17 ·
