Maximum Acceleration: I Got the Correct Answer
The discussion centers on a physics problem involving the motion of an object described by the equation y(X) = sin(x) and moving with a constant speed v. The correct answer for the maximum acceleration, derived as √g, was achieved by treating the motion as circular with a radius of 1. Participants debated the implications of constant speed on acceleration and the relationship between tangential and centripetal acceleration, ultimately clarifying that the direction of acceleration must be tangential to the curve.
  • Understanding of basic calculus, specifically derivatives and second derivatives.
  • Familiarity with concepts of circular motion and centripetal acceleration.
  • Knowledge of trigonometric functions, particularly the sine function.
  • Basic principles of kinematics and dynamics in physics.
  • Study the relationship between centripetal acceleration and velocity, specifically the formula a = v²/r.
  • Learn how to derive the second derivative of a function with respect to time, particularly for sinusoidal functions.
  • Explore the implications of constant speed on acceleration in non-linear paths.
  • Investigate the concept of tangential versus centripetal acceleration in varying motion scenarios.
Students of physics, particularly those studying mechanics, as well as educators and tutors looking to clarify concepts of motion and acceleration in sinusoidal paths.
rashida564
Position of an object is given by y(X)=sin(x), and moves with constant speed v. Find the maximum speed given that, the acceleration at the top shouldn't exceed g.
a=dv/dt
I got the correct answer which is √g. I solved it as if it were a circular motion with radius of 1. But got no idea why my solution did work.
rashida564 said:
Homework Statement:: Position of an object is given by y(X)=sin(x), and moves with constant speed v.
Please show your detailed work so we can check it.
Also, this problem statement is confusing to me. Is it saying that v(t) is constant, and the position y(x) follows a sinusoidal path? How can you find the "maximum speed" if the speed is constant?
It says the speed is a constant v. Whether you consider it v(t) or v(x) is immaterial. It asks for the maximum value of a constant given a constraint, not the maximum over time.
Thanks @haruspex -- I still am not understanding, but will just watch to see how the OP responds. Guess I'll learn something. :smile:
rashida564 said:
Homework Statement:: Position of an object is given by y(X)=sin(x), and moves with constant speed v. Find the maximum speed given that, the acceleration at the top shouldn't exceed g.
Homework Equations:: a=dv/dt
I think you just got lucky. What if it had been A sin(ωx)?
It's like asking for the maximum safe cornering speed on a non-uniformly curved track.
can you give me a hit of what should I do
What determines the acceleration at a given point on a curve if the speed is constant?
The direction of the acceleration. It must be tangential to the curve
Is it true this way because it will be a rotating vector, or I just got it by pure luck again😭😭😭
not sure though why should it v times v
You know that ##y = \sin{x}## describes the trajectory of the particle, and you want to find something relating to the acceleration in the ##y## direction, ##\frac{d^{2}y}{dt^{2}}##. What happens if you try finding the second derivative of ##y## with respect to ##t##? Then, what values can you substitute into this expression given the critical condition in the question?
No, no. Tangential acceleration would change the speed.
etotheipi said:
something relating to the acceleration in the y direction
Not in general, but in this case yes. E.g. consider rotating the axes a little.
You'd need to justify dv/dt = v2. Where did that come from? Remember |v| is given as constant.
that's from the rotation of axis. Like any vector. dA/dt= A*w. where w is the rate in which it changes it's direction. Not sure why this vector change it's direction by magnitude of v
If you want to justify it in terms of vectors you'll need to write it appropriately to be understood.
Do you mean that if ##|\vec A|## is constant then ##|\frac{d\vec A}{dt}|=|\vec A|\omega## where ω is .. what algebraically ?
It is not a circular motion.
Imagine it is a car going up a hill with constant speed v. The horizontal displacement of the car is x, the vertical one is y. The shape of the hill is y=sin(x). Determine the x and y components of acceleration at the top of the hill.
Yes sir sorry for my messy writing, this what I am trying to figure out, the left hand side is " |d→Adt||dA→dt| clearly g, the ##|\vec A|\## is v, but I don't get what's w
So how do you get ##|\frac{\vec{dv}}{dt}|=|\vec v|^2##?
w must be equal to v, but I don't know how to define w. like what's it's formula
What do you know about centripetal acceleration?
It's to the center and equal to v^2/r
And what is its direction relative to the velocity?
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 24 ·
