Maximum speed on conservative forces problem
5 replies · 4K views
fanie1031
1. A girl swings on a playground swing in such a way that at her highest point she is 3 m from the ground, while at her lowest point she is 0.5m from the ground. The acceleration of gravity is 9.8m/s^2. What is her maximum speed? Answer in units of m/s.
2. 1/2mVf^2 + mgyf = 1/2mVi^2 + mgyi
I made initial velocity to equal zero.
3. [Vf= (mghi - mghf)/ (1/2m)]^(1/2)
When I do this... I endup square rooting a negative number. What am I doing wrong?
on Phys.org
I'm using .5 as her initial height and 3 as her final height. Is that my problem? And velocity... I just assumed... that may be wrong. (Thanks for the quick reply by the way!)
OOh I got it! I did this:
v=[2(gVi-gVf)]^(1/2)
You sparked my thinking. Thank you.
The problem mentions nothing about air resistance so we can assume that our forces our conservative. This meas that the sum of your forces at position 1 (her highest point) is equal to the sum of the forces at position 2 (her lowest point).
KE1 + PE1 = KE2 + PE2
You can elimitate your KE1 because at her highest point the girls velocity is 0.
This leaves us with PE1 = KE2 + PE2 We expand this formula to:
mgh1 = (1/2)m[v(squared)] + mgh2
this can be simplified by canceling out all of your masses.
gh1 = (1/2)[v(squared)] + gh2
Now just plug in your values and solve for your velocity.
Edit: Nevermind, you beat me to it.
Oh thank you for going ahead and writting up the solution.
