Maxwellian velocity distribution vs. speed distribution
The discussion centers on the relationship between Maxwellian velocity distribution and speed distribution in three dimensions. The velocity distribution is expressed as $$g(v_x) \propto e^{-mv_x^2/2k_B T}$$, while the speed distribution incorporates an additional $$v^2$$ term, resulting in $$f(v)dv \propto 4\pi v^2 dv e^{-mv^2/2k_B T}$$. The key distinction lies in their integration over different coordinate systems, with the velocity distribution spanning from negative to positive infinity and the speed distribution limited to non-negative values. The mean speed for the Maxwellian is given by $$v_{mean}=\sqrt{(8/\pi) k T/m}$$, while the root mean square speed is $$v_{rms}=\sqrt{3 k T/m}$$ and the most probable speed is $$v_{mp}=\sqrt{2 k T/m}$$.
  • Understanding of Maxwellian distributions
  • Familiarity with statistical mechanics concepts
  • Knowledge of spherical coordinates in integration
  • Basic proficiency in calculus, particularly in handling integrals
  • Study the derivation of Maxwellian velocity distribution in detail
  • Learn about the Jacobian transformation in coordinate systems
  • Explore the implications of root mean square speed in thermodynamics
  • Investigate the applications of Maxwellian distributions in kinetic theory
Physicists, students of statistical mechanics, and researchers in thermodynamics who seek to deepen their understanding of particle distributions and their implications in physical systems.
weezy
Maxwellian velocity distribution is obtained by $$g(v_x)\propto e^{-mv_x^2/2k_B T}$$ and when extended to 3 dimensions the distribution becomes: $$\propto e^{-mv_x^2/2k_B T}e^{-mv_y^2/2k_B T}e^{-mv_z^2/2k_B T} = e^{-mv^2/2k_B T}$$
Now looking at the speed distribution we take a spherical shell in phase space between ##v , v+dv## and obtain: ##f(v)dv \propto 4\pi v^2 dv e^{-mv^2/2k_B T}##
My question is that are the two distributions equivalent since ##f(v)## has a extra ##v^2## term but logically the two seem equivalent?
The velocity distribution goes from minus infinity to plus infinity for each direction and peaks and has mean at v=0. The speed distribution goes from zero to plus infinity and has value zero for speed less than or equal to zero. (It is really undefined for negative speeds.) The mean value of the speed for the Maxwellian is ## v_{mean}=\sqrt{(8/ \pi) k T/m} ##. For the speed, ## v_{rms}=\sqrt{3 k T/m} ## and most probable speed is ## v_{mp}=\sqrt{2 k T/m} ##. Perhaps the rms speed is the place where your statement that the two seem to be equivalent is most applicable. It is necessary to compute the precise form of the speed distribution, (with the spherical shell), in order to compute ## v_{mean} ## and ## v_{mp} ##.
The difference reflects the fact that there are two different coordinate systems for the integration. In the first case the integral is over three dimensions with dv_xdv_ydv_z. The the second case the integral is based on spherical coordinates v^2dvsin\phi d\phi d\theta and then the angular variables integrate out to 4\pi.
Well the name says it all: You have distribution! So to transform from one distribution to the distribution of a function of the independent variables you have to take into account the corresponding Jacobian.
In your case you have given the velocity distribution, i.e., the number of particles in an infinitesimal cube ##\mathrm{d}^3 \vec{v}## in velocity space around ##\vec{v}## is
$$\mathrm{d} N = \mathrm{d}^3 \vec{v} f(\vec{v}).$$
Now you have ##v=|\vec{v}|##. It's clear that here the case is pretty simple, because you can just use spherical coordinates, in which
$$\mathrm{d} N = \mathrm{d} v \mathrm{d} \vartheta \mathrm{d} \varphi v^2 \sin \vartheta f(\vec{v}).$$
Now you want to "forget" about the angular distribution. So you have to take the integral over ##\vartheta## and ##\varphi##, i.e.,
$$\tilde{f}(v)=\int_0^{\pi} \mathrm{d} \vartheta \int_0^{2 \pi} \mathrm{d} \varphi v^2 \sin \vartheta f(\vec{v}).$$
Since in your case ##f(\vec{v})=f(v)##, you can do the angle integrals
$$\tilde{f}(v)=v^2 f(v) \int_0^{\pi} \mathrm{d} \vartheta \int_0^{2 \pi} \mathrm{d} \varphi \sin \vartheta=4 \pi v^2 f(v).$$
  • · Replies 38 ·
