Maxwell's Equations: Help to truly understand them
Maxwell's Equations are fundamental to understanding electromagnetism and the behavior of electromagnetic waves. The discussion emphasizes the importance of grasping both the differential and integral forms of these equations to appreciate their implications fully. A key point is that Maxwell's Equations can be used to derive the wave equation, which describes how electromagnetic waves propagate. The relationship between these equations and boundary value problems is also highlighted, suggesting that studying these concepts can deepen understanding. Overall, a solid grasp of Maxwell's Equations is essential for exploring advanced topics in electromagnetism and wave phenomena.
TFM
Help to fully appreciate Maxwell's Equations
Maxwell's Equations (Differential Form):
\nabla \cdot \vec{E} = \frac{\rho}{\epsilon_0}
\nabla \cdot \vec{B} = 0
\nabla \times \vec{E} = \frac{\partial \vec{B}}{\partial t}
\nabla \times \vec{B} = \mu_0 J + \mu_0\epsilon_0\frac{\partial \vec{E}}{\partial t}
Maxwell's Equations (Integral Form):
\oint_{closed surface} \vec{E} \cdot dS = \frac{1}{\epsilon_0}\int_{volume} \rho dv
\oint_{closed surface} \vec{B} \cdot dS = 0
\oint_{loop} \vec{E} \cdot dl = -\frac{d\Phi}{dt}
\oint_{loop} \vec{B} \cdot dl = \mu_0I + \mu_0\epsilon_0 \int_{surface}\frac{\partial E}{\partial t} \cdot ds
Okay. So this technically isn't a Homework Question as such. In another thread, I was told that to help with some of the more complicated parts of Electromagnetism, I need to fully appreciate what the original Maxwell Equations actually mean/represent.
Could anyone hare help me with this, Please?
Thanks,
TFM
Don't you have a textbook or something? A complete explanation, or even a sufficient explanation would almost certainly require a lot of background explanation and knowledge. It's hard to do that here.
I have 'Introduction to Electrodynamics' by David Griffiths
You still haven't asked any specific questions.
Well firstly, I'll put a link to the aforementioned thread:
https://www.physicsforums.com/showthread.php?t=276223
So how do Maxwell's Laws really relate to Electromagnetic waves? I know the speed of light (in a vacuum) is given from them by:
c = \frac{1}{sqrt{\epsilon_0 \mu_0}}c = \frac{1}{\sqrt{\epsilon_0 \mu_0}}
But how else do they relate to EM Waves?
TFM
Firstly... you can finesse through some mathematics with Maxwells equation and derive the "wave equation" -- which is a standard partial differential equation. This derivation is available EVERYWHERE, so you can look it up (I see no reason to slog through it here). Interesting enough perhaps in free space (because of the vector nature of the periodic propagating field disturbances... the exponential respentations of which you show in your link), solutions to the wave equation are even more interesting when you talk about "boundary value problems" ... things like reflection and refraction, propagating modes in restricted geometries (waveguides), interesting effects in materials (like second harmonic generation) etc. Maxwell's equations not only provide the wave equation, but they also restrict the boundary conditions in certain ways.
Therefore, to truly understand Maxwell's Equations, I suggest you take some form of a PDE / Boundary Value Problem course, or at least read up on such (there are other neat BVP's like heat flow equations... and the wave equation also can be related to sound waves: via vibrations on 1-D strings, d2-D drumheads, and in 3-D pipes). The text I used when I took such a course was an early edition of David Power's Boundary Value Problems. I was fortunate enough to have taken it BEFORE I took an upper-level undergraduate E&M course... I'd say it helped me enormously, which is why I've always personally been fond of EM, despite other's qualms (fellow grad students dreaded when we encountered the standard rite of passage in Jackson's Electrodynamics in grad school... I found it simply routine fun. :biggrin:)
So the Wave equations from Maxwell's eqn would be when you curl of the curl E/B and get, respectively:
\nabla^2\vec{E} = \mu_0\epsilon_0 \frac{\partial^2\vec{E}}{\partial t^2}
\nabla^2\vec{B} = \mu_0\epsilon_0 \frac{\partial^2\vec{B}}{\partial t^2}
and since nabla^2 B gives:
\nabla^2 B = \frac{\partial^2\vec{B_x}}{\partial x^2} + \frac{\partial^2\vec{B_y}}{\partial y^2} + \frac{\partial^2\vec{B_z}}{\partial z^2}
Edit, error in Latex above should be:
\nabla^2 B = \frac{\partial^2\vec{B_x}}{\partial x^2} + \frac{\partial^2\vec{B_y}}{\partial y^2} + \frac{\partial^2\vec{B_z}}{\partial z^2}and similarly for E:
\nabla^E = \frac{\partial^2\vec{E_x}}{\partial x^2} + \frac{\partial^2\vec{E_y}}{\partial y^2} + \frac{\partial^2\vec{E_z}}{\partial z^2}
\nabla^2 E = \frac{\partial^2\vec{E_x}}{\partial x^2} + \frac{\partial^2\vec{E_y}}{\partial y^2} + \frac{\partial^2\vec{E_z}}{\partial z^2}and so:
\frac{\partial^2\vec{B_x}}{\partial x^2} + \frac{\partial^2\vec{B_y}}{\partial y^2} + \frac{\partial^2\vec{B_z}}{\partial z^2} = \mu_0\epsilon_0 \frac{\partial^2\vec{B}}{\partial t^2}
and
\nabla^2\vec{E} = \mu_0\epsilon_0 \frac{\partial^2\vec{E}}{\partial t^2}\nabla^2\vec{B} = \mu_0\epsilon_0 \frac{\partial^2\vec{B}}{\partial t^2}
\nabla^B = \frac{\partial^2\vec{B_x}}{\partial x^2} + \frac{\partial^2\vec{B_y}}{\partial y^2} + \frac{\partial^2\vec{B_z}}{\partial z^2}
and similarly for E:\frac{\partial^2\vec{E_x}}{\partial x^2} + \frac{\partial^2\vec{E_y}}{\partial y^2} + \frac{\partial^2\vec{E_z}}{\partial z^2} = \mu_0\epsilon_0 \frac{\partial^2\vec{B}}{\partial t^2}
TFM
Edit: I'm not sure what went wrong above, but the order is slightly off. The final Equations should be for E:\frac{\partial^2\vec{E_x}}{\partial x^2} + \frac{\partial^2\vec{E_y}}{\partial y^2} + \frac{\partial^2\vec{E_z}}{\partial z^2} = \mu_0\epsilon_0 \frac{\partial^2\vec{B}}{\partial t^2}
and B:\frac{\partial^2\vec{B_x}}{\partial x^2} + \frac{\partial^2\vec{B_y}}{\partial y^2} + \frac{\partial^2\vec{B_z}}{\partial z^2} = \mu_0\epsilon_0 \frac{\partial^2\vec{E}}{\partial t^2}
