HEU_LL
- 6
- 2
- TL;DR Summary
- I have defined two materials (Material 1 and Material 2) which are actually the same material but located in different positions. However, after running the calculation with the BURN card, I am encountering an issue where all burnup information for Material 2 is zero, while Material 1 appears to be burning up normally.
Hello everyone,
I am currently working on a burnup calculation for a fuel assembly with repeated geometric structures using MCNP6. I have defined two materials (Material 1 and Material 2) which are actually the same material but located in different positions. However, after running the calculation with the BURN card, I am encountering an issue where all burnup information(power fraction(Initial input is 1,but output file is 0), burnup, mass, etc.) for Material 2 is zero, while Material 1 appears to be burning up normally.
Has anyone encountered a similar issue or have insights into what might be causing this problem? Any suggestions or advice would be greatly appreciated. Thank you in advance for your help!
