Meaning of operators for observables.
alexepascual
I understand that observables in quantum mechanics are represented by hermitian operators, which are converted into a matrix when expressed in a particular basis. I also understand that when the basis used is an eigenbasis of the operator, the matrix becomes diagonal, having the eigenvalues as diagonal elements, and those eigenvalues are the possible results of the measurement.
But I still think I am missing something, that I fail to visualize the connection between the math and the physical process.
I know of three things you can do to a state:
(1) You can unitarily change it, like under a force or just letting time pass
(2) You can make a measurement, which would change the state by eliminating some of its components.
(3) You can make a change of basis, which would leave the state alone and just change your description of it by rotating the frame of reference (in Hilbert space).
But I don't understand how the observable operators relate to the three points above.
I can see how the operator can, in its eigenbasis and when bracketed with the state vector, give a weighted sum of all the possible measurement resuts, which would correspond to the expectation value. But that's the most I can make out of it. And, again, I think I am missing somethhing.
If a state (pure) is represented by a state vector, and operators operate on state vectors to yield other state vectors; what is that operators corresponding to measurables do to the state vector? It can't be a change of basis because this is accomplished by a unitary operator. It can't be a real measurement because the operator is not projecting the state vector on a basis, unless it is already in its eigenbasis. And the meaning of these operators become even less clear when they appear multiplied times each other like in the conmutators.
I have started to explore this problem with spin operators, but an elementary treatment has not answered my questions. I realize that after reading a lot about angular momentum I might get to the point I understand. But I thought there should be some explanation of this independent of the particular states under consideration.
I am really confused. All I have read doesn't seem to clarify this puzzle.
I'll appreciate your help guys,
--Alex--
The description of an observable as a Hermitian operator is not strictly necessary from the point of view of measurement theory alone. One could simply describe a measurement by a collection of projectors onto the relevant eigenstates instead.
However, the formalism is useful because of the dual role that observables play in quantum mechanics. They can be things that are measured, but also they can be things that are conserved by the unitary part of the dynamics. The latter means that if a system starts in a particular eigenstate of an operator representing a conserved quantity, then it will remain in that eigenstate. It is easy to check that if H is a Hermitian operator, then e^(iH) is a unitary operator that conserves H. Hence, the Hermitian operators are useful because they can be used to describe both the unitary part of quantum dynamics and the measurement part.
Thank you sylboy. You mention a dual role of operators. Probably I can explore both roles separate, as otherwise it may become overwhelming.
With respect to the role they play in the time evolution, I have read (but never quite understood) that hermitian operators conserve probability. I think I need to study this more, but I think I would rather start with the other role you mention. (measurement)
After reading your response, I was thinking the following: To give you the different eigenvalues of a particular possible measurement, the operator's matrix needs to be diagonalized. When you diagonalize the operator, you are changing the basis, the same unitary operator used to diagonalize the observables operator is used on the state, to express it in the new basis. If the operator't matrix in a certain basis is not diagonal, the matrix itself contains all the information needed to construct the unitary matrix needed to diagonalize it. So, could we say that the function of the observable's operator is to provide all the information needed for the basis change, even if the operator used to accomplish that change of basis is not the measurable's operator itself but the unitary operator that is built based on information provided by the observable's matrix?
Maybe I am going in the wrong direction, but I am trying to build a conceptual scafold that can make sense to me, and which I can use as a frame of reference to later interpret and fill-in all the details. I can also understand that a task like this is somewhat personal, with each person having different preferences, depending on their personalities. I understand most people may prefer to just work with the operators, without worrying too much about their meaning, and later their meaning becomes apparent through their use. I can understand how that may work for them. I have never considered myself very good and efficient at heavy symbol manipulation, and for this reason I rely more on deeper conceptual understanding and sometimes on paradigms.
Sylboy, thanks again, and I hope you'll give me a few more insights.
--Alex--
From the perspective of measurement theory, a Hermitian operator is just a convenient summary of everything you could want to know about the outcome statistics of that measurement on any state. Another convenient summary would be the set of projection operators associated with the eigenspaces, or the set of eigenstates if the operator is non-degenerate. The latter is often more convenient for discussing the foundational issues of quantum mechanics, but in practice physicists find the former more convenient because of the close relationship to conserved physical quantities.
It is true that the operator contains all the information about the appropriate change of basis you need to make to figure out the outcome probabilities and post-measurement state. I don't know why you are trying to attach such a great significance to this piece of linear algebra, but you may choose to understand it in this way if you wish.
It is not true that Hermitian operators conserve probability, but unitary ones certainly do. This just means that the inner product of the state with itself remains constant. The interpretation of "conserve probability" in this statement is just that the probability that the system is in some state is always 1. To see why this is true you just have to note that the question "Is the system in some state?" corresponds to the identity operator, so it always has the value 1 under unitary evolution.
The measurement "rotates" the state. Perhaps it is bad to think of the measurement as "eliminating components."
alexepascual said:
... what is that operators corresponding to measurables do to the state vector?
You lost me on this one. The basis is a mathematical abstraction. I don't see how that can get in the way of a physical measurement.
alexepascual said:
... I thought there should be some explanation of this independent of the particular states under consideration.
The theory/formalism is much more clear when demonstrated in the abstract. The three things you mentioned above do not depend on a particular state. Are you looking to add as many more things to this list as possible?
I think you may be blurring the critical distinction between an operator and a matrix. There is much overlap in the sense that you can express (and even think of) the operator in terms of a matrix and you can use a matrix to find the various properties of an operator. But the operator itself is not strictly a matrix. As I understand it, the fundamental distinction between an operator and a scalar dynamical variable is twofold: 1) the commutation issue and 2) the fact that an operator is awaiting a state on which to operate whereas a scalar dynamical variable stands alone. A matrix also stands alone (can be treated without multiplying it on a state), so it may not be providing you with a comprehensive picture. In otherwords, when you are considering an observable Ω as a matrix, then you have already, whether explicitly or not, performed the operations <φi|Ω|φj>.
Sylboy:
I guess every person has a different way of learning, and I can understand how we can get impatient when other people try to grasp the problem from a different angle than the one we have chosen. I appreciate your comments though, and I have printed a copy to go over them as I keep thinking about this issue.
Turin:
With respect to your first comment:
Rotating the state can give you the state expressed in the eigenbasis of the measurement operator, but if the state corresponds to a superposition of different eigenstates, the rotation doesn't choose one of the eigenstates as the result of your measurement. I cound understand how rotating the states (in Hilbert space) can be part of the measurement, but I would bet it can't be the whole story. You would need a projector or something to complete the measurement. A rotation of the basis would not change the state, but a measurement does, as it chooses one eigenstate and sets the others to zero. Even if we ignore the selecting of a particular outcome and consider the rotation part, a unitary operator allows you to rotate the state, so why would you need the hermitian operator at all?
I am not really questioning . I know that there must be a reason, it is just that I think I am missing something.
I just meant that the operator operating on a state does not give you the eigenvectors or the eigenvalues unless the state is already expressed in the eigenbasis of the operator. Do I make any nore sense? In other words: when you find the eigenbasis of the operator, and diagonalize it using the needed unitary operators, only then you get to see the eigenvalues in the diagonal, and only when the state vector is expressed in this eigenbasis do the coefficients relate to the probability of getting the eigenvalues as results of the measurement.
I agree with you. I would like to understand this issue without having to refer to a particular system. But as I have failed, I am trying to use a two state system as an example. If I can understand these concepts without getting into angular momentum, etc. I would prefer to do that. I am trying to keep the "list" as short as possible.
With respect to your comment about my blurring the distiction about an operator and a matrix, I understand everything you are saying and totally agree. Maybe I didn't express myself clearly, but I understand the distinction. I understand that the operator can stand on its own and not become a matrix until you express it in some basis by bracketing with the basis vectors. That's what I meant by "the matrix of an operator". Like the Pauli matrices would be the matrices of the spin operators expressed in the z (+/-) basis.
Thanks for your input Turin.
alexepascual said:
... if the state corresponds to a superposition of different eigenstates, the rotation doesn't choose one of the eigenstates as the result of your measurement.
This statement makes me wonder if we might be talking about two different things. I am picturing an arbitrary state and an arbitrary measurement. Let's say we have an operatoer, &Omega;, that has an eigenbasis {|&omega;i>}, and let it operate on a state, |&psi;>. Mathematically, we would get:
&Omega;|&psi;> = &Sigma;&omega;i|&omega;i>.
Physically, however, we would get:
&Omega;|&psi;> ---> &omega;i|&omega;i>
with a corresponding probability:
&radic;(<&psi;|&omega;i><&omega;i|&psi;>)
which is generally nonunity. Since it is nonunity, the rotation is nondeterministic. Is that what you mean - how can the selection of eigenstate be nondeterministic?
I didn't mean a rotation of the basis, I meant a rotation of the state. You need the hermiticity as opposed to the unitarity because 1) the formalism requires real eigenvalues for observables, and 2) the value of the resultant eigenvalue (usually) contains all of the experimental information, which would be trivial if it were always unity. Therefore, you cannot get a meaningful formalism based on eigenvalued results by only allowing hermitian unitary transformations. I hope I'm not mixing stuff up; it's been over a year since my last QM instruction.
My point was that the operation inherently returns an eigenvalue of the operator, according to the formalism. Whether or not it looks that way when you write it down on paper is a different issue. The physical interpretation of the QM state is that its "length" is arbitrary and its "direction" alone completely determines the physical state. When the operator acts on the state (when you "look" at the state), it necessarily returns an eigenvalue and points the state in the corresponding direction.
alexepascual said:
... I am trying to use a two state system as an example.
I believe you mean that you are trying to use a 2 dimensional Hilbert space. The system can be in a superposition of two states, the superposition being its own distinct state, and therefore allowing an infinite number of distinct states. (I'm assuming you're talking about spin 1/2 particles.)
Turin,
Your answer gave me a lot to think about.
I was as a matter of fact missinterpreting you with respect to the rotation. I was talking about a rotation of the basis and you were talking about a rotation of the state vector. I think this is crucial and deserves some discussion.
A rotation of the state vector with respect to a particular basis would imply a chance in the coefficients (components) of the vector. This would represent a change in the physical object described by the vector.
What I mean by a rotation of the basis may a sloppy way of expressing it. (although I have seen it in some books). What I actually mean is this:
Every time you describe the vector you use some basis. So you could say that you are using a reference frame that coincides with (is aligned with) that basis. A change to another basis could be seen as a rotation of your reference frame so that it now aligns with the new basis. The position of the state vector here remains fixed with respect to any of the possible bases (with respect to the Hilbert space). It is just your point of view that changes. So the physical situation does not change, only your description of it changes.
With respect to the equations you list, the first one is:
Turin said:
Ω|ψ> = Σωi|ωi>.
Are you sure this is correct? Wouldn't it be:
Ω|ψ> = Σi ωi |ψi> or...
Ω|ψ> = Σi ωi |ωi><ωi|ψ> or...
Ω|ψ> = Σi ωi <ωi|ψ>|ωi> or...
Ω|ψ> = Σi ωi ci |ωi>
Some other questions (if you don't mind):
(1) to write these equations I had to cut and paste from yours. How do you make greek letters and subscripts on this forum?
(2) I noticed that your notation is very similar to Shankar. Is that the book you used?.
(3) I would assume you studied Quantum Mechanics in school (graduate studies?) What are you doing these days? anything related to physics?
I am myself presently unemployed. I used to work as an engineer but have a hard time finding a job now. I got a bachelor's degree in physics which doesn't help. I was planning to get my master's in physics because that is what I like, but now I am reconsidering. Even if I don't continue my formal studies in physics, I'll keep studying QM on my own.
Turin: thanks for your replies, they are helping me a lot in thinking about these issues in QM. Things are not clear for me yet but I feel I am making some progress.
Thanks again,
--Alex--
It should be
presuming that ωi are the eigenvalues of Ω and |ωi> are the corresponding eigenstates. I don't know how to wite the greek symbols (I also used cut and paste, but I do know how to do this:
\Omega | \psi \rangle = \sum_i \omega_i \langle \omega_i | \psi \rangle | \omega_i \rangle
which is much cooler anyway (click on the equation to find out how).
I think Turin means that on measurement a state is rotated onto the eigenstate corresponding to the outcome that was obtained. The unitary operator that does this depends on both the initial state |ψ> and the outcome |ωi>. It is not unique, since there are many unitary operators that do this.
I think it is better to regard the state update rule as a projection rather than a rotation becasuse the projection operators are unique and do not depend on |ψ>. This is a better way of thinking about it if you ever study the more advanced aspects of measurement theory, where state vectors are generalized into things called density operators and the notion of a projective measurement is generalized into something called a POVM (Positive Operator Valued Measure). Not all physicists have to study this, but if you are interested in the foundations of quantum theory or quantum computing and information theory then you will eventually come across it. I think quantum statistical mechanics uses this formalism as well.
Yes.
Basically. I imagine that one could probably make an argument for an exception, but I don't imagine that it would be altogether enlightening for our purposes.
I'm not sure I agree with this. In some ways, it does seem like a rotation, but I imagine that it could also involve reflections and discontinuities.
Do you mean as a consequence of a measurement. If I'm not mistaken, this is not consistent with experimental result. For instance, if the measurement were only to change the basis but leave the physical state alone, then I don't think there would be any non-trivial commutation of observables.
You are quite right. How sloppy (incorrect) of me. I wouldn't use your first suggestion, though.
Concatenate these strings: "&" "alpha" ";"
Yes. Everything about QM that I have learned in a formal setting has been from Shankar.
Yes. I graduate tomorrow as a matter of fact. I have no job prospects, so I am stressing more than anything else. We seem to have striking similarities in background and contemporary situation.
Can you give an example of
U1|&psi;> = |&phi;> and U2|&psi;> = |&phi;>
such that U1 /= U2.
For some reason, I just can't think of how to show that.
How would this then demonstrate the statistical dependence on |&psi;>?
U1|ψ> = |φ> and U2|ψ> = |φ>
such that U1 /= U2.
To specify a d-dimensional unitary operator, you have to give its action on at least d-1 linearly independent vectors (the last one will be fixed by orthogonality relations). There are no examples in 2-dimensions, which may be why you had difficulty finding an example, but here is one in a real 3-d space:
Suppose |1> and |2> and |3> are orthonormal basis vectors and we want to find a unitary, U, such that
U |1 \rangle = \frac{1}{\sqrt{2}} ( |1 \rangle + |2 \rangle)
We could choose
U |2 \rangle = \frac{1}{\sqrt{2}} ( |1 \rangle - |2 \rangle)
U |3 \rangle = |3 \rangle
but
U |2 \rangle = |3 \rangle
U |3 \rangle = \frac{1}{\sqrt{2}} ( |1 \rangle - |2 \rangle)
is an equally good choice.
If you are concerned that this is just a relabeling of the basis vectors then note that
U |2 \rangle = \frac{1}{\sqrt{3}} ( |1 \rangle - |2 \rangle + |3\rangle)
U |3 \rangle = \frac{1}{\sqrt{6}} (|1 \rangle - |2 \rangle - 2 |3\rangle)
is also a good choice.
I'm sure you can now come up with a continuous infitinty of other possibilities.
How would this then demonstrate the statistical dependence on |ψ>?
The state update rule is
|\psi \rangle \rightarrow \frac{\Pi | \psi \rangle}{|| \Pi | \psi \rangle ||}
where \Pi is the projector onto the eigenspace corresponding to the eigenvalue obtained in the measurement. This clearly shows the dependence on the state, but the operator involved is not dependent on the state and is uniquely defined (modulo some mathematical technicalities that arise for continuous variables).
Well guys, you gave me a lot to read. I'll have to take a break now and start working on something that perhaps can make me some money. I printed your posts and I'll read them tonight on the couch while my wife watches TV.
I think I'll answer tonight or tomorrow morning.
--Alex--
slyboy said:
To specify a ... unitary operator, ...
Of course; that makes sense. I don't know why I couldn't think of that. :rolleyes:
I'm still missing something. I don't see how this helps one understand the collapse. In fact, it seems more complicated than the observable operator formalism. If \Pi does not depend on the state, then what would prevent one from specifying \Pi to project |\psi\rangle onto a state |\phi\rangle for which \langle\phi|\psi\rangle = 0?
Slyboy: sorry for misspelling your name. It must be dyslexia. Other things came up and I was not able to take the time to think about your argument about the different unitary operators.
Turin:
States in Hilbert space could be visualized as points on a sphere. to one state, there corresponds only one point on the sphere. When we move the state vector, we are going prom point a to point b on the sphere. This motion can always be accomplished by a one of two rotations in the plane determined by both points and the origin. If you accomplish the change by a continuous motion or a sudden jump is not made explicit by the unitary operator.
In 2-D real space, a rotation matrix takes you form point a to point b on the unit circle, but although we call the matrix a "rotation" matrix, that matrix does not tell you that you are smoothly moving the thing through all the intermediate angles. The rotation matrix could very well represent the point dissapearing form position "a" and appearing at position "b". In this case, or in the Hilbert space case, I wonder if the matrix for a rotation of 180 degrees and that for a reflection would look different.
On the other hand, if what we are doing is changing basis, where each eigenvector is represented by a point on the sphere, as we are talking about many points, reflection would look different than rotation, but still the rotation matrix would not necessarily mean a smooth motion.
Now, when I suggested viewing a basis change as a rotation, I was not trying to be precise. I was just trying to find some way to visualize the thing, even if later I have to replace that concept by a more precise one. I understand orthogonal matrices are not only rotation matrices but also reflection and inversion matrices, and the same must be true for unitary matrices I guess.
I agree with you and I think you missinterpreted me. It was exactly my point that a change of basis alone can not represent a measurement.
On some equations you posted previously you said: "mathematically it would be like this.." and "physically it would be like this..". Without getting into the details and more on a philosofical note, I think that what we are trying to do with the math is represent as close as possible what is happening physically. I do understand that some times we may use terms whose "physical existence" is questionable and in other cases there may be no good math to represent the physical process. But I would guess in most of quantum mechanics there is a good correspondence between the "physical" and the "mathematical", this as long as we consider things like a state as "physical". I am not trying here to get into deep philosofical discusion, all I mean is that I was somewhat suspicious about your assertion about something being one way "mathematically" and another way "physically".
Slyboy and Turin,
To summarize a little our discussion, I think we kind of agree on the following:
(1) A measurement "could" be represented by a rotation of the state vector (which does not need to be continuous) to a position where it coincides with one of the eigenvectors of the measurement operator.
(2) The previous representation may not be the best. A projection may be a better way to visualize it or to carry out the calculation.
(3) If we have a measurement operator and a generic state vector, in order to carry out the multiplication you express both the operator and the vector in some basis. If the basis you chose is not an eigenbasis of the operator, when you multiply, you are not going to get each component of the state vector multiplied times the eigenvalue. In order to get that you have to make a change of basis to the eigenbasis of the operator. You achieve this change of basis using a unitary operator, which you apply to both the matrix and the vector (unless ine of them is already expressed in the eigenbasis). This change of basis does nothing to the physical state itself, it is only the description that changes. Once you have everything in the eigenbasis of the operator, (the matrix is now diagonal) then multiplying the measurement matrix times the state vector gives you a vector where each original component is now multiplied times the eigenvalue.
Do we agree up to this point?
Well even if this is correct, I fail to see the significance in this product. It appears that the change in basis was more crucial (it gave us the eigenvalues and the eigenvectors). But multiplying the matrix times the vector doesn't seem to accomplish much other than murking things up by mixing amplitudes with eigenvalues by multiplying them together.
The only use I can see in this is to put a bra on the left and then get the expectation value.
Someone may say that that's exactly what the operators are for, that thy give us a bridge between that classical quantities and the quantum world. I can understand that.
On the other hand, looking at the commutation relations, it appears that the operators have a greater significance than this. Maybe what I am trying to visualize can not be visualized, but I think there should be some meaning to the operators even if we stay in the quantum world and not try to make comparisons with the classical. I understand the correspondence principle has been important, but probably that was just a crutch.
So in summary, I take a state, I multiply it times a measurement matrix (yes I say matrix, not operator) and the matrix is not in the eigenbasis of the operator. What have I done to the state? If I multiply the state vector times two measurement matrices (like in a commutator), what have I really done?
alexepascual and slyboy,
You have converted me. I don't know what I was thinking. I now believe that the exact arguments that I made in favor of the rotation picture actually serve to better promote the projection picture. (I'm still awaiting slyboy's reply with interest.)
alexepascual,
Perhaps I was unclear when I distinquished the "mathematical" quality from the "physical" quality. What I meant was:
- when you "write it down" or "do the calculation" the writing contains a distribution and there is no way for the calculation to make a selection of a particular eigenvalue. The calculation can show a favored eigenvalue, but there is no way to be sure unless the state is prepared as an eigenstate.
- when you "do the experiment" the "display on the experimental apparatus" will "show only one of the eigenvalues" and will not give a distribution. Of course, if you "do the experiment" repeatedly, the apparatus will eventually develop the distrubution and so "agree with the math."
I didn't intend anything philosophical.
I agree with (1) and (2). I still don't quite follow the point of (3). Maybe you could give an example. I think what is confusing me about your (3) is that I see no need to first express the state in some obscure basis and then subsequently transform to the eigenbasis of the operator. Furthermore, if the state is an eigenstate (of the operator), then it does not matter whether or not it is expressed in the eigenbasis (of the operator); the operator will still return the original state multiplied by the eigenvalue. If the state is not an eigenstate, it can still be decomposed into a superposition of eigenstates (without applying any unitary operators?) (See your post, post #8).
Turin,
When I said I was not intending a deep philosophical discussion, I was talking about my own argument. I didn't mean that your arguments appeared to be philosofical. Actually I do like to think and discuss the philosofical fouindations and implications of quantum mechanics, but here I was trying to not to fall into that temptation as I wanted to focus on the math and its relation to the physical entities it describes.
Some of what you said in your last post is giving me food for though. I'll have to take some time to digest it.
I also want to go over the Slyboy's discussion about the unitary operators ( I haven't had time yet).
Hey guys !
By the way, I know that any observable is represented by a hermitean operator.
Now, is it true that any hermitean operator can be considered as representing an observable (?_?)
Humanino:
I don't know. Maybe Slyboy or Turin can answer your question. At this point, as I am focussing on observables, I am not interested in knowing if Hermitian operators may represent other things. If on the other hand I found that they are applied outside of quantum mechanics and that their use in another science makes their meaning more clear, I might be interested in looking into that. But given the very special role played by imaginary numbers in quantum mechanics, I doubt it very much this comparison would yield anything fruitful.
Slyboy:
Your argument about the existence of many unitary operators that take you from one point to another is convincing. We could also think of many different rotations that can take you from one point to another on the surface of a sphere. But you could though choose a rotation that moves the point within a plane that includes the origin. This would eliminate the multiplicity of unitary operators. But in its application to QM. it's dependence on the state would probably allways be a problem as you pointed out.
Turin:
You say:
To decompose the state into eigenstates, you first have to know what those igenstates are. Once you have the eigenstates, decomposing the state vector into the different eigenstates is equivalent to a change of basis. Now, maybe you say: No!, I start without any basis, I just have the abstract vector and then I express it in the eigenbasis of the operator!. OK, but I don't see in practice how you can describe a state without doing it in some basis. In paper you can write ψ but that doesn't mean much, it doesn't tell you anything about the particle until you give the components in some basis. If you ask the guy in the lab to give you a report on the state of the particle, he'll give you a list of complex numbers with units, where those units are base kets. He won't hand you a piece of paper with a letter ψ written on it.
It is not that you start with some obscure basis. I think you start with some standard basis, maybe a basis that is an eigenbasis of a previous measurement, and then you have to look for the eigenbasis that corresponds to the present measurement or measurable. To know what the components of the state vector are in this eigenbasis, you have to change basis, which you do with a unitary operator in which each column is an eigenvector expressed in the old basis. When you write this base-change with kets, it may not be obvious that you have a unitary operator, but you could identify a ket-bra product as exactly that unitary base-change operator.
I think I would have more comments, but is getting late and I have to go.
--Alex--
alexepascual,
I would say that while ψ is said to be abstract mathematically, it seems that it is not really abstract experimentally. I suppose it could be thought of as a point in its own basis. But, I don't think I agree with a decomposition into eigenstates as necessarily the same as a change of basis. I definitely see the similarities, but I would need more convincing, or more ponderance, before I accepted that. I'll try to think it through here for the benefit of whomever:
Let:
ψ( x ) = < x | ψ >
g( k ) = < k | ψ >
Eigenfunction expansion:
ψ( x )
= Σi φi( x ) ci
= Σi < x | φi > < φi | ψ >
Change of basis (i.e. IFT):
ψ( x )
= integralover k{ dk K(k,x) g( k ) }
= integralover k{ dk < x | k > < k | ψ > }
where K(k,x) is the Kernel of the transformation.
I'm not getting anywhere with this. I'll have to think about it.
Wow! I only went away for a couple of days and there is a lot of stuff to respond to. Please forgive me if I don't give every comment the attention it deserves.
Hey guys !
This has been an assumption made by theorists for many years. However, it has been shown theoretically and experimentally how to actually measure any Hermitian operator in quantum optical systems. I don't have the references to this work, because I'm not an expert in this area. I think they can do this in NMR as well. For other quantum systems, there seems to be no fundamental reason why the same techniques should not work. It is simply a matter of engineering the correct Hamiltonian for the system. This is technically challenging, but is coming within reach for a variety of systems due to techniques developed for quantum computing.
I'm still missing something. I don't see how this helps one understand the collapse. In fact, it seems more complicated than the observable operator formalism. If does not depend on the state, then what would prevent one from specifying to project onto a state for which ?
There is no difference from the operator formalism. You can derive one from the other. You cannot specify an arbitrary projector becuase you have to use the one that corresponds to the eigenvalue that you obtain in the measurement.
Consider a Hermitian observable A. The spectral theorem says that it can be decomposed as follows:
A = \sum_j a_j \Pi_j
where a_j are the eigenvalues and \Pi_j are the projectors onto the corresponding subspaces. You are probably used to thinking about eigenstates rather than projectors. If each eigenvalue is non-degenerate then the two notions are the same and we can write \Pi_j = | j\rangle \langle j | for some orthonormal set of states |j\rangle. For degenerate eigenvalues, there is some arbitrariness in choosing a complete orthnormal basis, but the projectors are still uniquely defined.
Now, when you make a measurement of A on a state | \psi \rangle, you obtain the eigenvalue a_j with probability
p(a_j) = \langle \psi | \Pi_j | \psi \rangle
and if the outcome a_j is obtained, the state collapses to
|\psi \rangle \rightarrow \frac{\Pi_j | \psi \rangle}{|| \Pi_j | \psi \rangle ||}
You may notice that the projectors are themselves Hermitian operators and so they can be regarded as observables. They correspond to the question "Is the value of A = a_j or not?". This is used extensively in discussions of the foundations of quantum mechanics, providing the basis for the Kochen Specker theorem and quantum logic. You may want to look these up because they are quite interesting.
I aplologise if I have been repeating things that you already know so far.
You will notice that nothing in the above really depends on the eigenvalues a_j. We need to consider them if we are interested in things like the expectation value of A, but for some purposes this is not relevant, particularly if we are talking about the abstract structure of measurements without a particular quantity (e.g. position, momentum, spin) in mind.
In that case, I can equally well specify a measurement by a collection of projectors \Pi_j satisfying
<br /> \Pi_j \Pi_k = \delta_{jk}\Pi_j<br />
<br /> \sum_j \Pi_j = I<br />
where I is the identity operator.
Similarly, given such a set of projectors, I can construct a Hermitian observable from them by multiplying each projector by a different number and taking the sum. Since the numbers are arbitrary, many Hermitian observables can be constructed from the same set of projectors, but they are all equivalent in terms of the probabilities of the different outcomes and the effect they have on the state. They may, however, have different expectation values and uncertainties. A simple example of this is given by the pair of observables x (position) and 2x.
The Hermitian observable picture comes into its own when we are really concerned with a particular physical system with a particular type of dynamics. From an abstract point of view, it is better to think about projectors. This is especially true if you make a measurement by interacting your system with another ancilliary one, doing a measurement on the joint system and then throwing the ancilliary system away. The notion of quantum state and quantum measurement has to be generalized to cope with this and Hermitian observables are not well suited to doing this.
In short, multiplying a state vector by an observable has got nothing to do with what happens in the measurement process. As you suggest, it is only useful for calculating expectation values, but I have already argued that this has little to do with the abstract structure of the measurement process.
However, multiplying a state vector by 1 - i \delta t A or e^{-itA}, where A is an observable is physically meaningful if you have a Schroedinger dynamics that conserves A, but again this has little to do with the measurement process.
The commutation relations are important, but we can even view them on the level of projectors rather than Hermitian observables. If two observables are incompatible (i.e. can't be measured simultaneously) then they do not commute. However, there will also be at least one pair of projectors, one from each observable, that do not commute. Personally, I take the significance of the canonical commutation relations [x,p]=i\hbar to be that x and p cannot be measured simultaneously. The right hand side simply tells us the degree to which they don't commute and essentially defines the constant \hbar, which simply tells us the scale at which quantum effects are important.
I think that argument only works in 3-dimensions. I don't doubt that you can find a way of introducing a canonical choice for a unitary operator by generalizing this idea though. However, I object to introducing such arbitrary things into the quantum formalism for no apparent reason.
slyboy,
Very enlightening. I believe this treatment rings a vague mind-bell. Let me see if I have this correct in my own words. To apply the projection formalism, one considers the observable as a weighted sum of projection operators. Given the result of the experiment as one of these weights (assuming for simplicity nondegeneracy), this will indicate which projection to apply to the state, regardless of the original state. That's brilliant! From this perspective, it almost seems like one doesn't even have to give a care to the original state, yet it is still preserved in the formalism for the possibility that it may be of interest. The dependence on the original state is built into the fact that only experimentally observed eigenvalues are statistically applicable.
Instead of decomposing the state (which experimentally cannot actually be "known" but only approached in definition after repeated measurements of identically prepared systems) into a weighted sum of eigenstates, one decomposes the observable (which is literally defined by the experiment and therefore perfectly well known to the experimenter) into a weighted sum of projectors. I like it!
I was determined not to come to the physics forum for the rest of the day. And here I am. I think this is becomming an addiction for me.
Turin:
I didn't like too much your characterization of the observable as a weighted sum. To me, when you braket the operator on both sides to get the expectation value you are doing a weighted sum. What I mean is that in that case the weighted sum concept appears to make a whole lot more sense because you got a weight, which is a probability, for each eigenvalue; and you really add things up.
But in the case of the projectors, I would see it more like just a decomposition of the observable. The eigenvalue would not be a weight, as there is no reason to think that a position measurement of 100A will have more weight than one of 5A. Well, that's just my view.
How about this: Before you measure, the operator would represent the possible outcomes, although the probabilities would be embedded in the state and not in the operator. After you measure, your measurement could be better represented by the projector, as now you know which of the eigenstates you got.
Now, if you multiply the state by the projector, you get the state that results from the measurement. To do this, you don't even need to include the eigenvalue, as you are going to throw away any coefficient you get (the probability now is 100%) and you need to normalize.
I guess we both agree to the correctness of what Slyboy, who seems to know a lot about all this stuff, says. What I am trying to find here is the best mental picture to accompany the theory.
Slyboy:
Thanks for your your input. You are helping us see things more clearly. I still suspect (probably I am wrong) that there is some hidden (hidden to me) meaning in the operators, specially in connection with the conmutators.
If the operators were to represent rotations in three dimensional space, I could see how the commutator would make sense. You take a vector in 3-d space, apply rotation A, then apply rotation B, (this would be BA) and then you start with the vector in the original position, apply rotation B, then apply rotation A (AB product). In each case you may get a different final position, and this may very well be represented by a commutator (the difference between both final positions).
Is there any sequence of measurements that can illustrate the commutation relation?
Welcome to the club.
... in the case of the projectors, I would see it more like just a decomposition of the observable. The eigenvalue would not be a weight, ...
I agree; my phraseology was poor. I intended an analogy to the alternative picture, but my phraseology could admit great confusion. Perhaps I should have called it an "identified decomposition" (identified to the eigenvalues/eigenstates of the observable). I think we agree in spirit, but in letter you have definitely put it more elegantly.
alexepascual said:
Slyboy,
If the operators were to represent rotations ..., I could see how the commutator would make sense.
This was my original reasoning for declaring the operators to induce a rotation on the state. But I think that I now see clear reasoning against the rotation picture.
This is very similar to what the commutation relations do say, but you have to understand the connection between unitary operators and Hermitian ones. Rotation operators bear a similar relationship to symmetric ones. To describe this in any detail, I would have to get into the theory of Lie algebras, which would take too long to explain here.
Briefly, any unitary operator can be written as U(t) = e^{-itA} for some Hermitian operator A. Actually, this defines a whole family of unitaries parameterized by t. Consider two unitaries U(t) = e^{-itA}, V(t) = e^{-itB}. Unitaries are like the complex version of rotation matrices, so doing U followed by V is not the same as V followed by U. This is expressed by the commutator of U and V, which is given by
U(t)V(t)U^{\dagger}(t)V^{\dagger}(t) \neq I
where I is the identity operator. How does this relate to the more familiar commutators of Hermitian operators? Well, consider what happens when t is a small parameter, call it \delta t.
The operators can be expanded to first order as
<br /> U(\delta t) \approx I - i \delta t A<br />
<br /> U^\dagger(\delta t) \approx I + i \delta t A<br />
<br /> V(\delta t) \approx I - i \delta t B<br />
<br /> V^\dagger(\delta t) \approx I + i \delta t B<br />
Plugging this into the previous equation and only keeping terms up to first order in \delta t gives
[A,B] = AB - BA \neq 0
which is the more familiar commutation relation. A and B are called the generators of the unitaries U and V and we have seen that if a pair of unitaries don't commute then their generators will not commute either. The converse is true also.
Now, momentum is the generator of spatial translations and position is the generator of translations in momentum space (i.e. changes of velocity). We see that the fact that position and momentum do not commute means that if I move a quantum particle followed by changing its speed, I don't get the same wavefunction as if I do the same things the other way round.
I don't think there is a sequence of measurements that illustrates the exact form of the commutation relations, but it is easy to see that observables don't commute. More accurately, it is easy to see that a measurment must disturb the state of the system, which amounts to the same thing. Consider a spin 1/2 particle prepared in the z-up state. If we measure z-spin followed by x-spin then the result of the z-spin measurement is certain to be spin-up. However, if we measure x-spin followed by z-spin then the first measurement prepares a state that has 50/50 chance of being z-up or z-down. The fact that the measurement statisitics are different means that the x measurement must disturb the state of the system. This is equivalent to saying that x-spin and z-spin do not commute.
I realized that this explanation might be a little confusing. It is better to think of changing the reference frame in which you are describing the wavefunction rather than "moving a quantum particle" because there is no physical way to translate the wavefunction instantaneously.
Slyboy:
Your explanation may be what I was looking for. I just have to take the time to go over it and probably go back to the books too. While the books didn't appear to be giving me the intuitive picture I was looking for, perhaps now, using your explanation as a guide, it will make more sense.
Turin and Slyboy:
It's been a very interesting discussion we had since the beginning of this thread. I thank you both for your help. I am intending to take a break for a few days from this forum while I digest all this in the evenings. Let's see if I can stick to my decision.
Thanks again,
Alex Pascual
alexepascual said:
Turin:
I have to pointed out that there is a flaw in your statement, Alex. Actually states in Hilbert space could be visualized as points not only "on" the sphere, which we traditionally call "Bloch sphere", but also points within the sphere. Here are the rules: Pure states will be points "on" the sphere; mixed states, however, are just points within the sphere. And actually one mixed state could be decomposed into the combination of two pure states points on the Bloch sphere. Anyway, I found your guys' discussions on quantum measurement are very enlightening.
That's true, but I was trying not to introduce such complications and I believe that the discussion has mainly been about pure states so far. One could also quibble that we should consider projective Hilbert space rather than the Hilbert space itself due to the ambiguities of normalization, but I don't think that is too important at this level.
  • #31
Chasingwind:
Welcome to the thread!.
I agree with Slyboy. I think I have read that Hilbert space is a space of "rays" were the main thing is the "angle" between rays. The sphere was for me just a way to visualize the position of the rays. I was not too concerned with the length of vectors.
I don't remember much about the Bloch sphere. But from what you are saying, I can see some similarity with the chormaticity diagram, in which pure colors are represented on the periphery and mixed colors in the interior.
I am going to do some reading tonight to refresh my memory about the bloch sphere.
  • #32
The bloch sphere is just the sort of visualization you are talking about for two-level quantum systems. Pure states in a 2-d complex Hilbert space can be parameterized by two angles, so you can visualize them on a sphere in 3-d.
The interior of the sphere represents "mixed" states, which are a generalization of the sort of quantum states we have been discussing. Briefly, there are two ways in which mixed states can arise:
1. If you have a source that emits quantum states, but you are not exactly sure what states are being emitted. You can then describe your ignorance by a classical probability distribution over the pure states. The collection of states along with their classical probabilities is called an ensemble, but more than one ensemble can give the same predictions for quantum measurements. Therefore, we decsribe the state by something called the density operator, which takes the same form for enembles that give the same predictions.
2. If you have a composite system, for example a particle and its environment, then the total system may be in a pure state. However, if you consider the particle on its own then it cannot be described by a pure state, since it might be entangled with the environment. To describe the particle on its own, we do an operation called the "partial trace" to eliminate the environmental degrees of freedom. It turns out that you get exactly the same sort of density operator as in case 1.
Some philosophers make a big deal of the difference between 1 and 2. They call 1 proper mixing and 2 improper mixing. However, as far as the maths of QM is concerned, the two are completely equivalenet.
  • #33
Slyboy:
I am already somewhat familiar with mixed states vs. pure states. During my undergraduate studies I worked on a project which consisted in studying the transition from quantum to classical behavior. At that time I was exposed to the density operator, mixed states, decoherence, dissapearence of the off-diagonal elements, etc. This project was kind of a survey of the different ideas. Considering that my knowledge of quantum mechanics was not solid, I can not say that my understanding was good. But I got a rough idea of the main concepts.
With respect to the Bloch sphere, I think I could use it to think about pure states, as long as I stay on the surface of the sphere and don't go inside. When you say that the Block sphere is the kind of visualization that I was talking about, I wonder if you mean the kind of understanding that I was seeking about the meaning of operators from the beginning of this thread. If that is what you mean, I agree, or at least it looks like it might help me gain that understanding. I mentioned at one point I was planning to study two-state systems but I didn't want to get too deep into angular momentum. Well maybe this sphere will allow me to do that. Actually now I remember seing the sphere before, but I never understood it 100% and I didn't remember it was called a Block sphere.
In this particular case, the measurable operators would be represented by the Pauli matrices, so if I got all the elements, the state vectors and the operators, then I can see how they are related and what they represent.
Now, I understand I may loose generality, as I have read that the Pauli matrices have some peculiarities, such as being both Hermitian and Unitary.
So I'll see if I can focus on this on my spare time for the comming week.
Chasingwind:
Thanks for mentioning the Bloch sphere, As I tell Slyboy, I think it will help me understand the connection between state vectors and operators for the case of pure states.
  • #34
Pure states of a 2-d system can be represented by a density matrix
\rho = \frac{1}{2} \left ( I + \vec{r}\cdot\vec{\sigma}\right )
where I is the identity operator, \vec{\sigma} is a vector with the 3 Pauli matrices as its entries and \vec{r} is a real, 3-dimensional, unit vector. The vector \vec{r} is the Bloch sphere representation of the state.
There are more observables than just the Pauli matices, but any Hermitian operator can be written as:
H = \alpha I + \vec{\beta}\cdot\vec{\sigma}
where \alpha is any real number and \vec{\sigma} is any real 3-d vector.
As I mentioned before, a measurement of an observable can alternaticely be represented by projectors, and in this case the possible projective measurements are given by pairs of projectors
\Pi^{\pm}(\vec{r}) = \frac{1}{2} \left ( I \pm \vec{r}\cdot\vec{\sigma}\right )
where \vec{r} is a unit vector labeling the measurement and the \pm corresponds to the two possible outcomes. Note that the measurement projectors correspond to opposite points on the Bloch sphere.
  • #35
slyboy said:
... any Hermitian operator can be written as:
where ... \vec{\sigma} is any real 3-d vector.
Did you mean "\vec{\beta} is any real 3-d vector?"
slyboy said:
... the possible projective measurements are given by pairs of projectors
This clarifies quite well how the projectors can depend on the state. Good stuff. :smile:
  • #36
SlyBoy and Turin:
Thanks for your posts. I can't say anything right now because I have to think about it. I prited it out and I'll study the subject tonight.
  • #37
Hi guys,
After this long silence, I wanted to let you know that I have been thinking about the issues discussed in this thread and I have learned a good deal, but I have not gotten to the point I feel I have an answer to my original question. I have some ideas, but I am not sure.
I want to thank you all, your posts have helped me a lot, and have made my search for understanding less lonely. (I can't talk to my wife about QM)
Anyway, this thread is getting kind of long. I am planning on starting at least two new threads on more specific questions I ran into while trying to understand the meaning of operators:
Thread: Understanding the commutator.
Thread: The momentum operator as the generator of translations
So I'll consider this thread practically closed, unless you are a new visitor to the thread who feels there is more to be said. Otherwise, I invite you to my two new threads.
