Temperature Measurement: Are All Thermometers Created Equal?
The discussion centers on the discrepancies in temperature readings from different thermometers when measuring the same object. A thermocouple recorded a temperature of 20°C, while a thermistor indicated 24°C. The primary reasons for these differences include calibration issues, the timing of measurements, and the thermal contact between the thermometer and the object. Proper calibration using ice water and boiling water is essential for accurate readings, and environmental factors must also be controlled during measurements.
  • Understanding of thermocouples and thermistors
  • Knowledge of calibration techniques for temperature measurement
  • Familiarity with thermal conductivity principles
  • Awareness of environmental factors affecting temperature readings
  • Research calibration methods for thermocouples and thermistors
  • Learn about thermal contact and its impact on temperature measurements
  • Explore the effects of ambient temperature on measurement accuracy
  • Investigate best practices for simultaneous temperature measurements
Students in scientific fields, laboratory technicians, and anyone involved in temperature measurement and calibration processes.
barzani
What is the difference in temperature with different thermometers for the same object?
Thanks !
Science news on Phys.org
Hllo Barzani, :welcome:
Ideally they should all agree and measure the same temperature ... :rolleyes:
Is that really what you mean to ask ?
Thanks
Suppose we have a one thing we want to find the temperature
Testing with thermocouple: 20 C
We will test with the thermomister : 24 C
With and ...
What is the cause of these differences?
I can't tell from here. One of the two -- or both -- may be wrong, badly calibrated, ... Or the object under scrutiny is warming up in the time between measurements, or ...
Thing to do is calibrate the two measurement devices: measure in water with ice to find 0 ##^\circ##C and in boiling water to find .. at least the same value (which may not be exactly 100 ##^\circ##C)
I agree with BvU ... calibration would be the obvious reason for differences
This is 2 reasons
The 1-body may change the temperature at intervals between them
2. No calibrating machine
Is there any other reason?
Why can not I find something on the Internet
good
but we have more another cause ?
We need more details on how you're doing these measurements. They may not be making the same measurement under identical conditions. Are these in contact with the surface of your object? How do you ensure that it achieves good thermal contact with the object and is not influenced by the ambient environment?
barzani said:
This is 2 reasons
Things can go wrong for so many reasons that even the internet can't come up with all of them :smile:
By the way, this thread smells like a lab assignment and belonging in the homework forum...
yes, and that would have to be taken into account ... so therefore use both measurement systems at the same time to negate that problem
the thermometers SHOULD have been calibrated as part of the manufacturing process
For good quality ones, that shouldn't be an issue
For el cheapo ones, who knows what they use to calibrate the sensors. "You pay your money and you take your chances"Dave
it is goodwe can also tell
The temperature-sensitive material is not directly in contact with air and is heated by thermal conductivity. This is a self-limiting factor؟؟؟؟؟؟؟؟/
good thanks
see above my reply and tell me it is correct?
This is just an urgent question asked at the university asking and answering
Consider all the conditions for each device
So we have been doing your assignment for you?
Zz.
The theme music from the movie "Jaws" starts playing softly in the background, and starts building...
  • · Replies 0 ·
