Measurement Uncertainty Problem in MIT OCW 8.01x
The discussion centers on calculating the uncertainty of the ratio (0.781±0.002)/(0.551±0.002), with differing results from Professor Walter Lewin's video and an online calculator. The professor's answer of (1.417±0.008) contrasts with the calculator's output of (1.417±0.006), leading to confusion about the correct method for uncertainty calculation. Participants highlight that the correct approach involves using fractional errors and Pythagorean addition for independent uncertainties, which confirms the calculator's result as more accurate. The conversation also emphasizes the importance of understanding underlying assumptions in statistical methods, particularly in engineering contexts. Overall, clarity on uncertainty calculations is sought, along with recommendations for further reading on the topic.
AdrianMachin
What's the answer to (0.781±0.002)/(0.551±0.002)? Well, here is the answer (1.417±0.008) that professor Walter Lewin said in one of his videos. I checked this in an online uncertainty calculator and it turned out 1.417±0.006.
n/a
I tried the online calculator. I'm a bit confused and I need an explanation or a great guide or tutorial on these kinds of calculations. Thanks.
n/a
if C = A/B then fractional errors add using Pythagoras (if errors are independent) thus ΔC/C = √( (ΔA/A)2 +(ΔB/B)2) which confirms 0.006 as correct for actual error in in C (i.e C × ΔC/C )
Likes AdrianMachin
It is unfortunate that many courses seem to teach that as the only way to evaluate the resulting uncertainty. It is a statistical argument, based on the idea that you would be unlucky for both underlying uncertainties to be at the extremes of their ranges. That is fine for many purposes (though it pretends that the underlying uncertainties are sort of Gaussian, whereas they are often more like uniform). But to an engineer dealing with tolerances this is dangerous. If the radius of a bolt has been spec'd to a manufacturer as to be within a certain range, and the radius of the hole through which it must pass is spec'd to another manufacturer as being in some other range, it would be most unwise to discount the possibility that the bolt will be cast with the widest allowed radius and the hole bored with the smallest.
Professor Lewin used the engineer's approach. (But he was slightly off - it should be +/-0.009.)
Likes AdrianMachin
Agreed - I didn't actually check the source video and merely answered the mathematical question as posed, using the standard assumption of Gaussian errors. This underlines a general point about the need to make tacit assumptions clear - especially in statistics!
Thanks a lot. Is there any book or tutorial on these subjects? (I guess I should look for statistics books, right?). My native language is not English so I'm confused what do we call them in English? I mean "Errors" or "Uncertainties" or "Accuracy"?
Thank you so much, but I didn't understand what was the calculations behind the engineer's approach in this case?
Here are three slightly different approaches that yield 3 different answers.
(1) Direct computation.
largest numerator = 0.781 + 0.002 = 0.783, smallest denominator = 0.551 - 0.002= 0.549, so largest ratio = .783/.549 ≈ 1.426.
smallest numerator = 0.781-0.002 = 0.779, largest denominator = 0.551+0.002 = 0.553, so smallest ratio = .779/.553 ≈ 1.409.
The ratio lies between 1.417 - 0.008 and 1.417 + 0.009
(2) calculus-based calculation (OK for small errors):
$$f(x + \Delta x, y + \Delta y) = f(x,y) + f_x(x,y) \Delta x + f_y(x,y) \Delta y + \cdots ,$$
where
$$f_x = \frac{\partial f}{\partial x}\; \text{and} \;f_y = \frac{ \partial f}{\partial y} $$
are the partial derivatives of ##f(x,y)## and "##\cdots##" stands for higher-order terms in ##\Delta x## and ##\Delta y## that we are dropping.
In our case, ##f(x,y) = x/y##, so ##f_x = 1/y## and ##f_y =- x/y^2##. For ##x = 0.781, y = 0.551## this gives
$$f(x + \Delta x, y + \Delta y) \doteq (.781/.551) \Delta x + (-.781/.551^2) \Delta y$$
The largest value occurs when ##\Delta x = 0.002, \Delta y = - 0.002## and the smallest value occurs in the opposite case. This gives an error bar of about ##\pm 0.009##.
(3) Statistical estimate. We can use the previous approximate expression for ##f(x + \Delta x, y + \Delta y)## (with the higher-order terms dropped), but now regarding ##\Delta x, \Delta y## as independent random variables with standard deviations of ##\sigma_x## and ##\sigma_y##. We are dealing with the special case in which ##\sigma_x = \sigma_y = 0.002##, but the general formula below applies whether or not the two standard deviations are equal. Well-known statistical formulas imply that the standard deviation of ##f(x + \Delta x, y + \Delta y)## is
$$\sigma_f = \sqrt{ f_x^2 \, \sigma_x^2 + f_y^2 \, \sigma_y^2}$$
In our case we have
$$\sigma_f = \sqrt{(1/.551)^2 (.002)^2 + (-.781/.551^2)^2 (.002)^2} \doteq 0.006,$$
giving a final error bar of about ##\pm 0.006##
Likes AdrianMachin
where
In our case we have
Thanks A LOT, Ray. I really appreciate your help :)
Do you have recommendations on books or websites to read further?
