Measuring Reaction Time with a Simple Device
The discussion revolves around a problem involving the measurement of reaction time using a simple device, which consists of a cardboard strip marked with a scale and two dots. The task is to determine the appropriate distance from the lower dot to place a mark corresponding to a reaction time of 50.0 ms.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the equation h=1/2gt and its correct application, with some questioning the resulting values and conversions. There is confusion regarding the units and calculations related to the height corresponding to the reaction time.
The discussion is ongoing, with participants providing feedback on each other's calculations and clarifying the correct formula to use. There is a recognition of arithmetic errors, and some participants express concern over the accuracy of the values being calculated.
Participants are navigating through potential misunderstandings regarding unit conversions and the implications of the formula used for calculating height based on reaction time.
lgen0290
The figure below shows a simple device for measuring your reaction time. It consists of a cardboard strip marked with a scale and two large dots. A friend holds the strip vertically, with thumb and forefinger at the dot on the right in the figure below. You then position your thumb and forefinger at the other dot (on the left in the figure), being careful not to touch the strip. Your friend releases the strip, and you try to pinch it as soon as possible after you see it begin to fall. The mark at the place where you pinch the strip gives your reaction time.
(a) How far from the lower dot should you place the 50.0 ms mark?
I tried to use the equation h=1/2gt.
I got 24.5 cm=(.5)9.8m/s(5s)
Looking at it further, it seems that is 24.5 m, not cm, so I'm not sure. 24.5 meters is not right for sure, and neither is 24.5 cm.
lgen0290 said:
[b
It should be (1/2)gt^2.
But wouldn't that make the number even bigger? Is the reaction time after 50 ms really 122.5 cm? It just doesn't sound right.
You are right -- it doesn't. But the value comes out to be 1.225 cm, which does. Please at least do your arithmetic correctly.
Thanks. You could have simply pointed out that my conversion was incorrect on the seconds.
Sorry. I didn't mean to be rude, but so many people take our help for granted . I'm sure you are not one of them, and your mistake was genuine. We are :cool:, I hope.
13K
