Measuring the intensity of light
This discussion focuses on measuring light intensity, specifically in relation to a sodium lamp's filament current. The proposed method involves using a photocathode to emit electrons, which are then measured by a galvanometer to infer light intensity. However, the efficiency of photocathodes is limited, with quantum efficiency often below 0.01%. Alternatives such as photodiodes and photomultipliers are recommended for more accurate measurements. Additionally, a comparison photometer or a Bunsen grease spot photometer can provide practical solutions for measuring visible light intensity.
  • Understanding of photocathodes and their quantum efficiency
  • Knowledge of galvanometers and current measurement
  • Familiarity with photodiodes and photomultipliers
  • Basic principles of light intensity and photon emission
  • Research the efficiency and applications of photodiodes in light measurement
  • Explore the design and functionality of photomultipliers
  • Learn about the construction and use of comparison photometers
  • Investigate the principles behind Bunsen grease spot photometers
Researchers, physicists, and engineers interested in optical measurements, particularly those focusing on light intensity and photon detection methods.
N0b0dy
Hi, I'm trying to find out how changing the current fed through to a filament (e.g. sodium) of a lamp would change the light intensity. To determine the relationship, I will first need to find out how to measure the intensity of light. I've thought of one possible way to do it, but the measurement would not give me a direct expression of the intensity of light. Here it is if anyone wants to give me some potential feedback as to whether this would work:
Shine the light onto a cathode made of a metal that the light can emit electrons from. Electrons will then be emitted and will be attracted towards an anode connected to a galvanometer. The current measured will be related to the intensity of the light, where a higher intensity obviously yields a higher current.
Is there any other practical (and relatively simple) way to measure the intensity of light that will result in measurements that are direct expressions of the intensity?
Cheers.
Science news on Phys.org
A CCD or a photodiode would do the job I should think.
So is my description of a potential setup okay? I gave it some further thought and I believe that if I can obtain a value for current, I should able to observe the number of photons and hence the intensity because I=q/t. Hence if I divide the total charge per second by the charge of an electron I should be able to get the number of electrons per second and therefore the number of photons per second. The number of electrons per second is directly proportional to the number of photons per second, correct? So my measure of intensity will be number of photons per second?
The only issue here is that there are no photocathodes that have 100% quantum efficiency. If you're using a metal as your photocathode, then that's even worse, since metals, at best, have a QE of the order of 10^{-2}%. So there will be plenty of photons that didn't produce a single electrons.
Photodiodes, photomultipliers, photodetectors, etc. tend to be more efficient than your current set up.
Zz.
Cheers.
When you refer to "the intensity of light" do you mean just the visible part of the spectrum
or the whole of the spectral band that will be emitted most of this ,with a filament lamp,being in the infra red?
if you are looking at just the visible frequencies you might consider using a comparison photometer.If expense is an issue a Bunsen grease spot photometer might give some meaningful,but crude, results.For this you will need a suitable piece of paper and a spot of something like oil or butter.Google for details.
  • · Replies 17 ·
  • · Replies 207 ·
13K
