Measuring the speed of light with chocolate and a microwave oven
The forum discussion centers on measuring the speed of light using chocolate and a microwave oven, as introduced by a high school physics teacher. Participants highlight the experiment's reliance on standing waves within the microwave, emphasizing that the distance between hot spots corresponds to half the wavelength. Key errors in the methodology are identified, including the assumption of horizontal wave travel and the complexity of three-dimensional standing wave patterns. The discussion concludes that while the experiment may yield approximate results, it is fundamentally flawed due to these misconceptions.
  • Understanding of standing waves in electromagnetic fields
  • Familiarity with microwave oven physics
  • Basic knowledge of wave properties and measurements
  • Concept of three-dimensional wave patterns
  • Investigate the principles of standing waves in confined spaces
  • Learn about microwave oven design and its impact on wave behavior
  • Explore advanced wave measurement techniques in experimental physics
  • Research the mathematical modeling of wave patterns in three dimensions
Physics educators, experimental physicists, and students interested in practical applications of wave theory and microwave technology.
Science news on Phys.org
It could also be used to measure the frequency of the microwave, which is not as well known as c.
The method, of course, uses the fact that someone else measured the frequency of the microwave radiation. It's just an alternative way of measuring / knowing time.
I think that's splendid. What a great way to engage all chocolate lovers in the experimental method!
Cheese lovers, too! I've seen http://www.bbc.co.uk/mediacentre/proginfo/2012/46/dara-o-briains-science-club.html instead of chocolate.
from the OP's link:
Edit: when I made this measurement I forgot that I was measuring peaks of a standing wave which are half the wavelength of the microwave. So really, you should find the distance between the soft spots and multiply by 2 to get the wavelength. Thanks, Lord Axil. Somehow I must have missed a soft spot when measuring, which automatically corrected this factor of two.
More likely, he didn't realize his method was wrong in principle, but he got lucky and two errors canceled out.
The big conceptual error is assuming that the EM waves are traveling in a horizontal plane, so you can assume the distance between the spots = the wavelength (or half a wavelength, if you don't like the answer you got the first time!). The only "waves" that will produce heat spots in a fixed location are standing waves, and in a rectangular box like a typical microwave the standing waves are three dimensional. They can be very complicated - the wave can reflect off the walls, roof and floor of the box and make several "orbits" around the box before it repeats. What you are measuring is only a slice cut through that 3-D wave pattern. If you want to explore this further, it might be interesting to repeat the experiment at several different heights from the floor to the top of the oven, and compare the different patterns you get. Make sure you measure the positions of the spots relative to the sides of the oven, so you can "stack up" the different layers correctly.
The "real" wavelength inside the oven is something like ##\sqrt{kx^2 + ly^2 + mz^2}/n##, where x y and z are the width, height, and depth of the oven, and k,l,m,and n are four unknown integers. If you knew the values of k,l,m, and n, you could relate that to the pattern of spots you measured. The only problem is that you don't know what the integers were.
AlephZero said:
from the OP's link:
The big conceptual error is assuming that the EM waves are traveling in a horizontal plane, so you can assume the distance between the spots = the wavelength (or half a wavelength 1/2, if you don't like the answer you got the first time!). The only "waves" that will produce heat spots in a fixed location are standing waves, and in a rectangular box like a typical microwave the standing waves are three dimensional. They can be very complicated - the wave can reflect off the walls, roof and floor of the box and make several "orbits" around the box before it repeats. What you are measuring is only a slice cut through that 3-D wave pattern. If you want to explore this further, it might be interesting to repeat the experiment at several different heights from the floor to the top of the oven, and compare the different patterns you get.
The "real" wavelength inside the oven is something like ##\sqrt{kx^2 + ly^2 + mz^2}/n, where x y and z are the width, height, and depth of the oven, and k,l,m,and n are four unknown integers. If you knew the values of k,l,m, and n, you could relate that to the pattern of spots you measured. The only problem is that you don't know what the integers were.
That's pretty much the argument in the link I posted (he has some nice pictures to go along with it). Basically, it seems like this experiment only "works" because there will usually happen to be some hot spots whose distance apart is at least in the right order of magnitude, and then you can increase your precision either by hand-wavy measurements or by adding in factors of two as needed. :D
(I'll admit, though, I was kind of disappointed when I found out this experiment doesn't really work... it was one of my favourites in high school.)
posts 6,7 good insights...
I almost didn't post the link wondering about such...I was thinking reflections but wondered if there was some way manufacturers suppress them...then decided against that since it would seem to dimish delivered power [efficiency]...already not great...and it seems there are metal interior walls so anything outside would seem to have minimal effect.
  • · Replies 30 ·
13K
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 50 ·
  • · Replies 25 ·
  • · Replies 16 ·
