Mechanical Energy and Electricity
To determine how much electricity can be generated from a force of 10,000 N, it's essential to understand that force alone does not equate to energy; work is calculated as force times distance. For example, pulling a 10 kg box up 10 meters over one hour results in a power output of approximately 0.027 watts, which translates to 0.000027 kWh. The discussion emphasizes the importance of mechanical advantage and efficiency in converting mechanical energy to electrical energy. A typical estimation shows that a person on a stationary bicycle can generate around 102 watts under optimal conditions. Understanding the relationship between force, distance, and time is crucial for calculating energy output effectively.
lorenzotr
Hi, my question is rather simple.
Supose you can generate 10 000N, by any means, such as pedaling a bycicle.
What calculations should you make to know how much electricity would 10 000 N of force will generate.
-Assuming a generator efficiency of 100%, leaving friction aside, etc.
An example would be, how much electricity will i produce by pulling a string attached to the rotor of the generator, and the total force that will exert during 1 hour will be 10,000 N?
If you also please tell me how i can convert the result to kWh?
I have a very basic understanding of physics, and if you think i would not be able to understand your answer at this stage, may you please tell me what prior reading i should make before asking this question, or if you may give me a very detailed answer to my question.
By the way, this is an amazing forum, and all its participants are really making an effort to help others. Thank you to you all.
Welcome to PF.
Newtons are a force, not an energy (and there is no "total force" over time) and so there is no direct relationship between the two. However, given the mechanical advantage required to get a person to generate 10,000 N of force, I'd say they'd probably be able to generate zero energy.
Work (energy) is force times distance. Power is force times distance divided by time. That and mechanical advantage (divide or multiply by the ratio of the lever arms or gear ratios) are the only concepts you need here.
Thank you very much for your answer.
So let's take this for example:
I pull a box which weighs 10 Kg, attached to a pulley.
The pulley is at a height of 10 meters. And i pull the rope for 10 meters, so the box will be at a height of 10 meters. Then, let's assume that i do this process in a total of 1 hour. Then will that be right:
(10 Kg * 10 meters)/3600 seconds = 100/3600
Is that right so far? If yes, what will 100/3600 equal to? Newtons? How can i convert my answer to kWh? May you please give me an example of how you would have solved this? Thanks.
A kg is 9.8 N, so it is 10*9.8/3600=0.027 Joules/second (watts)
Kwh and watt-hours are energy, watts is power. .027 watts for 1 hour is .027 watt-hours or .000027 kWh.
An easier way to estimate this would be as follows:
A 155lb person on a stationary bicycle burns about http://www.nutristrategy.com/activitylist.htm" . If you optimistically assume a 50% efficiency in the human converting food energy to mechanical energy and 50% efficiency converting the mechanical energy into electrical energy then you are generating 88 kcal/hr of electricity which is 102 watts.
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
