What is the Force on a Barge Being Pulled by a Horse Across a River?
  • Thread starter Thread starter kierans
    Forces Mechanical
kierans
A horse is of the bank of a river pulling a barge in the same direction. Suppose the horse pulls on the rope with a force of 8600 N at an angle θ = 18Degrees to the direction of the motion of the barge, which is headed straight along the positive direction of an x-axis. The mass of the barge is 9500 kg, and the magnitude of its acceleration is 0.12 m/s2. What are the (a) magnitude and (b) direction (relative to positive x) of the force on the barge from the water?
You should show some work. At least draw a force diagram for yourself and post what you get for the sum of forces in the x and y directions.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
