Mechanics behind laminar motion of rigid body
The discussion focuses on the mechanics of a rigid sphere rolling down an incline, emphasizing the concept of laminar motion, which refers to the rotational motion where all points on the sphere move parallel to one another. The forces acting on the sphere include gravitational force components and friction, leading to the equation Icmdω/dt = Rf, where R is the sphere's radius. Laminar motion is compared to fluid laminar flow, highlighting that while the sphere's points move in circles, they maintain a consistent velocity based on their distance from the center of rotation. The conversation also connects torque and angular momentum, illustrating how torque produces angular acceleration from the perspective of an observer at the center of rotation. Ultimately, the relationship between translational and rotational movements is crucial for understanding the sphere's motion down the ramp.
negation
A ridig sphere is rolling from left to right down an incline plane with an angle elevation of β
In the y -direction, FN = mg cos β.
In the x-direction, mg sin β - f
(where f is the frictional force: μsFN)
The laminar motion is then given by Icmdω/dt = Rf (where R is the radius of the sphere)
What is the significance of the laminar motion and what is the reasoning behind it being derived?(how is it derived?)
The sphere has translational and rotational motion.
Laminar motion would be the rotational motion, in which case all points on the sphere move parallel to one another, with the velocity of the point a function only of its distance from the centre of rotation. This is similar to laminar flow of a fluid where the fluid moves in what can be described as sheets parallel to one another, except for the sphere the points are moving in a circle. That's the best I can explain it.
Can you see now that this is just the torque (Rf) producing an acceleration ( dw/dt) about the centre of rotation, from the perspective of an observer moving with the centre of rotation.
Of course, as the sphere moves down the ramp, to obtain the movement of a point from the perspective of an observer on the ramp, one adds together the translational and rotational movements.
I just realized laminar motion is another fancy name for torque or Newton's version(second law) for rotation.
Torque is the first time derivative of angular momentum.
τ = I(dω/dt) = r.F
How does the above then connects to:
dx/dt = rω → d2t/dt = r(dω/dt) = r2f/I ?
where f = friction.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
