How Does a Chain Hoist Work Mathematically?
A chain hoist functions as a force multiplier, utilizing the mechanical advantage derived from the number of turns in the chain. The most common design features an input chain loop that drives an output lifting chain through a step-down gear unit, often a planetary gear system. The basic mechanism involves two gears of different diameters, where pulling the chain rotates the gears and alters the length of the chain loop. For instance, if the larger gear has 24 teeth and the smaller has 20, pulling in 24 links of chain raises the load by 2 links, illustrating a mechanical advantage of 12 times the force. Understanding these mechanics mathematically reveals the efficiency and effectiveness of chain hoists in lifting applications.
g.bashyam
Can anyone explain the mechanics of a chain hoist and its mechanical advantage, in mathematical terms,?
thank you
Bashyam
It's a force multiplier.
You look the number of turns of the chain and this number multiplies the original force.
There are several different types of chain hoists. The most common type seen today has an input chain loop that drives the output (lifting) chain via a step down gear unit inside the hoist's housing. I think the gear unit is a planetary one.
The simpest form of chain hoist consists of a pair of discs of different diameters, locked together with their centres aligned. The two gears on the pedal crank of a ten-speed bike are what you should picture. The gear "teeth" are designed to mate without any chance of slipping with the chain being used.
The chain comes from somewhere, pases over one of the gears from (say) left to right, drops down and around an idler wheel. From there it goes up and over the SECOND gear, again from left to right, and then goes off somewhere. The cheapest way is to connect the two "somewhere" ends of the chain together.
Suppose the larger gear as T teeth, and the smaller has t teeth. If you pull in enough chain to rotate the paired gears 1 revolution clockwise, then you have removed T links of chain from the hanging loop, and added t links feeding off the smaller gear into the loop. So the loop gets shorter by ( T - t ) links, and since the loop goes down to the idler and then back up, the idler rises by ( T - t ) / 2 links.
So you exert a force through a distance of T links, and get an output through ( T - t ) / 2 links.
If the two gears have 24 and 20 teeth, for example, you pull in 24 links of chain to raise the load 2 links. 1 / 12 the distance means 12 times the force
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
