Calculating Projectile Force from Rotational Velocity of a Throwing Sling
  • Context: Undergrad
  • Thread starter Thread starter Riley Werling
    Mechanics
The discussion revolves around calculating the rotational velocity of a sling and using that information to determine the force exerted by a projectile launched from the sling. The scope includes practical application and mathematical reasoning related to projectile motion and rotational dynamics.
  • One participant seeks guidance on determining the rotational velocity of a sling and its relation to projectile force, expressing difficulty in understanding existing resources.
  • Another participant clarifies that the whirling speed is influenced by the user's choice and is a function of the effective length of the sling and the rotational speed.
  • It is suggested that the center of rotation can be assumed to be at the shoulder, with considerations for the arm's position.
  • A participant inquires about the effective length of the sling and the user's ability to whirl it, prompting further exploration of the user's arm speed.
  • Participants propose measuring the number of rotations made in a minute or a shorter duration to estimate the whirling speed.
  • One participant calculates the rotational speed in revolutions per second and introduces a formula for determining the speed of the sling pouch based on its effective length.
Participants generally agree on the need to measure the user's whirling speed and the effective length of the sling, but there is no consensus on specific values or methods for calculating the projectile force.
Limitations include the lack of specific measurements for the user's arm speed and the effective length of the sling, as well as the absence of a clear method for translating rotational velocity into projectile force.
This discussion may be useful for individuals interested in the mechanics of projectile motion, particularly in the context of using slings or similar devices for launching projectiles.
Riley Werling
Hey, I am not sure if this should be posted somewhere else, if so if you could direct me it would be much appreciated. So my question is how would i find the rotational velocity of a sling and how i could use that to calculate the force of a projectile from said sling. I've tried doing some research online but most of what I've read is way over my head so i was hoping someone here might be able to help me.
Thanks for any and all help you guys provide.
I assume that you are talking about a real sling - that is two thongs and a pouch which are whirled around until one of the thongs is released and the projectile flies free ?
The whirling speed is really determined by choice by the person using the sling . The speed picked up by the projectile is a simple function of the whirling speed and the effective length of the sling .
The effective length of the sling is the length of the thongs plus some additional length from your arms .
So how fast (rpm) can you whirl a sling and what is the effective length of your sling ?
Hint : For simplicity you can assume that the centre of rotation for the whirling is at you shoulder . Remember that your arms will most likely be bent .
So how fast (rpm) can you whirl a sling and what is the effective length of your sling ?[/QUOTE]
Sling would be 48in long and idek what rpm would be.. can't find an average anywhere online socichave no clue
How fast can you whirl your arms around ?
Pretty fast, if youre asking for a number i couldn't tell you
Whirl you arm as fast as possible and count the number of rotations made in a minute or if you can't manage a complete minute try thirty seconds .
100
So 100 turns in 1 minute or 100 rpm . Good .
100/minute is 100/60 = 1.67 revs/second .
The speed of the sling pouch as it goes around in a circle is given by 2 * pi * L * (revs/second) where L is the effective length of the sling .
L= 48 inches but we'll convert that to metres for our calculations . So we'll use L = 1.2 metres .
Do you want to try working out the pouch speed ?
  • · Replies 60 ·
  • · Replies 47 ·
