Mechanism Needed for a Compact, High-Torque Transradial Prosthetic Arm
  • Thread starter Thread starter KavehSanaei
A team is developing a transradial prosthetic arm featuring a mechanical claw designed for strength and precision, targeting a pinching force of 8 Nm. They face challenges in maintaining torque during gripping actions lasting several seconds to minutes, requiring zero backlash for safety. Suggested mechanisms include cam systems, zero-degree ratchet systems, hydraulic or pneumatic locking, and leveraging the motor's intrinsic torque. Concerns were raised about achieving zero backlash, with recommendations for using compliant materials or springs to assist in maintaining grip. The team seeks further suggestions and detailed designs to enhance their project.
KavehSanaei
Hello everyone,
I'm collaborating with a group of engineering friends to develop a transradial prosthetic arm that uses a mechanical claw for gripping. This prosthetic is designed for physical activities, demanding both strength and precision. We're aiming for a pinching force of around 8 Nm (~70 lb-in) and are using a low-torque, high-speed motor (e.g., ElectroCraft RPX22) combined with a 100:1 gearbox.
Our challenge is maintaining this torque during the gripping action, which could last from several seconds up to a few minutes. The mechanism must ensure zero backlash during pinching for safe use.
We're exploring various mechanisms to hold the claws in place effectively:
  • Cam mechanisms
  • Zero-degree ratchet systems for zero backlash
  • Locking via hydraulic or pneumatic pistons
  • Utilizing the intrinsic torque of the motor and gearbox
Additionally, the mechanism needs to be compact and lightweight since it is a prosthetic.
We're looking for suggestions. What mechanism would you recommend for maintaining the claw's position under torque in a compact and lightweight design? We're open to ideas, experiences, and any suggestions you might have.
Thank you in advance for your input and ideas!
Welcome to PF.
I'm not familiar with the term "transradial" in the context of a prosthetic arm. Are you referring to the radius bone, or is there some other meaning? Thanks.
And can you upload some drawings of your concepts so far? Use the "Attach files" link below the Edit window to upload a PDF or JPEG image of your work
Below I have attached a rough drawing of what we are trying to design. Both sides of the claw need to move independently. Two motors move each side of the claw independently. The gearboxes drive a cable and pully system that articulates the claws. We want the calws to have zero backlash once they are in position.
I also included an example picture of a transradial (below the elbow) prosthetic. It being transradial is not relevant to the mechanism itself.
How are you going to achieve zero backlash in this? Can you post a more detailed drawing?
Instead of Zero backlash, which is rather difficult in the real world, I suggest a rather hard compliant material covering the jaws/grippers -- maybe a semi-hard polyurethane. Polyurethane came to mind because it is not attacked by most chemicals and can be formulated and cast in about any hardness and shape you want.
This could be chosen for maybe a millimeter of compression at maximum force.
[edit/afterthought] If you Really require Zero Backlash, use a spring on the grippers to hold the grippers closed and use the motor to open them.
Cheers,
Tom
p.s. please keep us updated on your progress/solutions, we like to learn too!
Likes hutchphd and berkeman
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
