Meteorite heading towards earth
  • Thread starter Thread starter josephcollins
    Earth Meteorite
A meteorite with an initial velocity of 2.00*10^4 m/s is calculated to collide with Earth at a final velocity of 2.15*10^4 m/s, based on energy conservation principles. There is a debate about the correctness of dividing by 2 in the energy equations, with some arguing that the change in potential energy should be considered differently. The discussion also touches on the terminology surrounding meteoroids and meteorites, clarifying that a meteoroid becomes a meteor when it enters the atmosphere. Concerns are raised about the potential for high-velocity impacts, suggesting that significant warning time is typically expected for large objects. The conversation highlights the complexities of calculating impact velocities and the implications of high-speed collisions with Earth.
josephcollins
Hi ppl. I have a short question. A meteorite of mass m has a velocity u=2.00*10^4 m/s when it is at an infinite distance from the earth. It eventually collides with the eath with a velocity v. Calculate v. given are the radius of earth(6.37*10^6m) and go=9.80Nkg^-1)
I used the argument that the change in kinetic energy is going to be equal to 0.5m(v^2-u^2) which also equals GMem/2Re which resolves to goRem/2. Equating and calculating gives 2.15*10^4m/s. Could someone verify that this is correct and that potential energy or total energy is not neglected in my reasoning? thanks, joe
I don't see why you divided by 2. (The change in PE should equal g R_e m)
Wow! That meteorite had quite the bounce to it to achieve that high and fast of an arc, don't you think?
Or perhaps your prof meant meteor?
I'll bet the prof meant meteoroid on its way to becoming a meteorite. (If the meteoroid burns up--becoming a "shooting star"--then it would be a meteor.)
Regardless, that's one heck of a meteoroid to make it through the atmosphere with no apparent loss of mass. :smile:
Most scenarios seem to imply that massive objects hitting our planet would be traveling at a speed that would give days if not weeks of warning.
Is there any reason that a meteor should not hit the Earth at a very high relative velocity? Even one traveling at 80% the speed of light would be difficult to see coming, and hence be something of a surprise!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
