Method for proving the collatz conjecture, would this work?
firlz
Would it be possible to prove the collatz conjecture indirectly by demonstrating rules that apply to 'Collatz-like' conjectures? (I call anything where you simply change the values in the 3n+1 part of the conjecture to other values, holding everything else the same a Collatz-like conjecture)
For instance if you could demonstrate that
A. all infinitely increasing sequences of a Collatz-like conjecture follow [insert rule].
B. all sequences that loop in a Collatz-like conjecture either contain '1' as part of the loop, or else [insert condition].
C. when set to 3n+1, A requires that there be no infinitely increasing sequences, and B requires that all loops contain '1'.
Would this prove the conjecture true? (I cannot think of an A and B that are both true and lead to C, but if someone found it, would it prove the conjecture?)
Conversely if you had A and B as above, but instead of C had
D. When set to 3n+1, A requires that there be at least one infinitely increasing set
or
E. When set to 3n+1, B requires that there be at least one set that loops and does not contain '1'
would you be able to disprove the conjecture?
Mathematics news on Phys.org
Sure. It would be a more powerful proof, with the Collatz conjecture as special case.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
