Method to produce and measure velocity of a standing wave
To measure the velocity of a standing wave, the formula v = fλ can be applied, where f is frequency and λ is wavelength. The experiment can utilize a string as the medium, with vibrations initiated by a suitable source that controls the frequency. Observing the standing wave allows for easy measurement of wavelength at the antinodes. Additionally, exploring different mediums like liquids, gases, or solids can provide varying velocities for comparison. This approach will help establish a relationship between wave velocity and other variables.
Rampant
I'm in a Year 10 physics class. We have been asked, for homework, to design an experiment to measure the velocity of a standing wave. No other information has been given other than that.
I reproduce the exact instructions we were given, since the guidelines suggest I should:
Physics Design Prac
The velocity of Standing Waves?
You are to find a way to measure the velocity of a standing wave that you can make. You must change that velocity somehow, and find a relationship with another variable.
Good luck!
I did some research into waves and standing waves and I found that to find the velocity of a wave I use the formula v = f\lambda. I'm not quite sure how this formula applies to a standing wave, since a standing wave doesn't really move... was I supposed to measure the speed of the individual waves that make up the standing wave? Or the speed at which the standing wave vibrates at the antinodes?
Initial research into types of standing waves suggests I could use a string for the medium. I'm not sure what I could use to start the vibrations in the string though. Any help would be greatly appreciated.
To generate a wave you must have a source, and the source has a frequency ... your device, so you control the frequency.
Once you can see the waves you can measure the wavelength. For standing waves this should be easy.
That should be enough ... if you want to extend this try different liquids or gasses ... each will have its own characteristic velocity. You can even use solids ...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
