Mgf of a random variable with added constant
To find the moment generating function (MGF) of the random variable Y = Z + c, where Z follows an exponential distribution, the correct approach involves using the expectation E[e^(tY)] = E[e^(t(Z+c))]. The initial attempt to integrate with f(z+c) was incorrect, and using the proper f(z) in the integral would yield the desired result. The discussion emphasizes the importance of transforming random variables into known forms for easier calculations. This technique is valuable in probability and statistics for deriving expectations. The user expressed gratitude for the clarification and is now able to proceed with their exercise.
WantToBeSmart
Hey,
I have a pdf of a random variable Z given. I am being asked to calculate what the moment generating function of a r.v Y= Z + c will be where c is a constant in ℝ
I tried to calculate it in the following way:
\int^∞_0 e^{(z+c)t} f(z+c)dz where f(z) is an exponential pdf with parameter λ.
but it proved to be an unsuccessful method. Could anyone please show me the right direction? I know I could use Jacobian transformation but I'm sure there is an easier method.
Thank you in advance!
I wouldn't even mess around with the integral. Here is something I would try:
Y = Z + c where Z ~ exp(\lambda) and c is a constant. Then,
E[e^{tY}] = E[e^{t(Z+c)}]
Now do you see what you might be able to do?
I think it definitely solves this problem! Now I can proceed with the rest of the exercise. Thank you Robert!
You're most certainly welcome.
As a side note, this sort of thing is a rather valuable technique in prob/stat. That is, if you want to know about a certain RV, or a certain expectation, lots of times it is best to work it into some form you already know.
Of course, you would have gotten the same result had you used the correct f(z) dz in your integration, instead of your _incorrect_ f(z+c) dz.
RGV
RGV
Checked that and it was another mistake I was making. Thank you for pointing this out!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
